Rod Brg Readings
Results 1 to 14 of 81
Rod Brg Readings
    Default Rod Brg Readings
    Anyone care to read the "tea leaves" here ,The BBC Clevite rod brg inserts are from a jet boat motor with about 5 hrs on it , as seen they all have similar characteristics but some to a greater degree. The Crank is a new Scat unit and still looks perfect , rods were resized, its obvious that some "junk" has passed thru them from a diffferent issue (circumferal scores and partical embedment) but the "dotted" spotty patterns that are pervasive to some degree in all are curious. We know what we think , anyone else Thanks in advance Merry Christmas everyone Tom
    Olympia, Washington
    Was the oil milkshaked?? Looks like water got in the oil.
    Quote Originally Posted by Oldelmn8tr View Post
    The residual oil in the pan was a little dark and smelled of fuel a "smidge" and it had some "cold block" condensation in the upper engine but no "milkshake" (that we know of ) Tom
    Arroyo Grande
    Check measurements on that crank..I'd like to see pics of it also...what in the hell went thru that motor?? some of the bearings appear to be darkened? or is it just the pics...what was oil pressure on that motor. also...what are the clearances on the bearings to crank??
    Spiral out MikeF's Avatar
    The crank not cleaned before being assembled..........What do the main bearings look like?
    Nov 2008
    Orangevale CA
    My vote was going to be foreign liquid in the oil,,
    also the cold oil temp wont burn off the contaminate's..... ( just my opinion )...Eric
    ps : Have a Merry Christmas
    Quote Originally Posted by Unforgiven View Post
    The motor lost a cam (the "junk"), Cold OP was 70 psi , Crank looked perfect and rd clearance was .002 They may appear darkend due to the photo ? Tom
    Quote Originally Posted by MikeF View Post
    Mike I would agree with you (re the emmbeded particals ) but the raised spots are perplexing , i'm leaning to the moisture too (Mains are similar btw)
    Cantard 71hallett's Avatar
    snow bank
    How do the lifters look? Can I get a pic of a couple of those?
    What weight oil were you running? When this engine was buiit, did it sit for a long time before it was run? This almost looks like the assembly lube dried up before it ran, or was crap to begin with, or just a dirty build to start with. I don't think what we see is water damage.
    Did you build this engine?
    Why the guessing game...what do you think? (my bet is you KNOW what it is)
    Senior Member katchenup's Avatar
    vacaville ca.
    What kind of brake in oil did they use? And did they change it after brake in ? Hope they used the proper assembly lube, And not lube with graphite.
    What ever it is If you find out Tom let us know.
    Merry Christmas Tom, Rhonda, And josh.
    Steve and Janet
    All the grate minds took all the good answers.
    Tom. looks like a dirty assembly and high viscosity oil with a tight clearance tossed in for good measure. I'm sure you've seen an oil washed bearing before. Again the key here is dirty and tight. The tight is what is rolling the babbit of the bearing, the dirt is whats putting the racing grooves in the bearing.
    Morgan Hill
    I'm going to throw my ..02c into the ring...
    It looks like you have an oil wash problem, caused by too much cold oil flow, sometimes by fuel diluted oil and have seen it on alcohol engines also..
    I would also concur on the debris, but that looks secondary to me...
    These look as though it was run hard or overreved on very cold oil with too much oil pressure...
    GT
    GT
    Senior Member miketeast's Avatar
    maryland
    water flashing off...real hot oil and water.
    Team FTL
    Horsepower Homo
    Centistoke Fag
