EGT senders
Results 1 to 9 of 9
EGT senders
    Placentia, CA
    Default EGT senders
    What is the best way to check EGT senders?
    steveo143 AKA DiMarco 21 II
    Ada, Michigan
    There is no sender Steve.
    It's just two different kinds of wire twisted together.
    When you heat it up it puts out different voltages.
    Default Output
    Quote Originally Posted by steveo143 View Post
    There is a scale for most, using a volt meter to ground....I have the scale for "Split Second" senders that is quite close to the industry standard....Ray
    LOUD BOATS SAVE LIVES
    Placentia, CA
    I should have called them thermocouples, I get no reading on my gauge from either side.
    kinda off subject, but not really does anyone know of a backpressure gauge stout nuff to just screw into a manifold and leave it? i'd like to put a backpressure gauge in 1 of my manifolds and have it so i can see it. no idea of where to get something that'd hold up. i use my compression gauge on cars at the o2 locations, but that's low heat and pressure.
    Ada, Michigan
    I use an old oil pressure gauge but have it on a length of copper tubing away from the headers. 1/8 npt check valve.
    Some times with electronic displays, the two wires getting crossed will cause issue. Never seems to be an issue with cheap ole analog guages. As Mark said, a digital ohm meter will show a voltage as it heats up. Check the splice connections, make sure the insulation is not crimped in the connection, and the connections are tight.
    thanx mark, nutha great idea from a yankee
    Ada, Michigan
    Well........isn't anyone going to comment on my dipstick ?
