Pan Gasket
Results 1 to 5 of 5
Pan Gasket
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    Default Pan Gasket
    What's the best pan gasket for a MKIV BBC with a milodon pan?
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    waterloo
    This one is going to get real good!
    Wags
    One piece fel-pro.
    Colorado Springs
    I have used the one peice felpro mark IV gasket with no luck on a milidon pan. Last year I used a fiber Mr. Gasket and had pretty good luck. I have also noticed I had a better long term seal if I loctited the bolts. I had to use quite a bit of silicone on the outside edge of the pan lip. If I were to use silicone I would use the permatex cheese wiz style tube called,
    "The Right Stuff".
    Senior Member eliminator's Avatar
    Roanoke VA
    Gorilla Glue if its a ford
    Spider Monkey Racing
    FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
    [email protected]
    Ohio
    Mr. Gasket or Felpro have worked for me. Some silicone at the mating pionts and bolt it down. I've reused both several times before replacing. I also made my own stud kit for it. Nuts and lock washers. They stay tight for me.
    Tim
