casale in-out spring preload
Results 1 to 14 of 17
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Default casale in-out spring preload
    What is the proper amount of tension on the spring that presses the ball bearing against the shift crank in the in and out housing? I need to tighten mine up, as the handle doesn't want to stay where I put it, but i'm not sure if it's ok to just tighten it, or if the spring should be replaced. Could I pull out the spring and give it a stretch?
    Enough so it doesn't pop out.
    Sorry...couldn't resist.
    Mohave Valley/Quartzsite
    Quote Originally Posted by Ronboats View Post
    Basically what Steel said. I wouldn't think it needs to be stretched, well at least I've never seen it necessary. There should be two divits on that shift crank shaft where the ball bearing locks into when it's in gear and out of gear so I would tighten it until it locks into those divits. Do you have a locking handle for when it's in gear? I'm assuming your having a problems with the handle staying put out of gear???
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Make sure the detent hole isn't full of crap, too.
    Frst Round Runnerup Hondog's Avatar
    Turlock, CA
    I may have missed it but did anybody ask if he has a whirlaway? If so it will never stay in no matter how tight the detent ball is.
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Pretty sure in another thread we figured out Ron is running a non-whirlaway deal.
    On my Hondo, I ended up running a cable to shift the v-drive. It would not stay in without it. The resistance in the cable held it in.
    Ron, more reason to get a whirlaway. Get a hold of J.J. Beaverfab.
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    Of coures there's the old trick of just moving the lever forward on the splines so it hits the case and can't pop out...
    That's the word I was looking for!!!
    X2 with what Morg said!!
    My bad!! I assumed he had a whirlaway.. We all know what assume means.
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    Since I haven't really dealt with a non-whirlaway I have a question, do they have a locking handle and would it work in this case?
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    Yes you can use a locking handle on a non whirlaway unit. the spring really has nothing to do with the box staying in gear. The box is held in gear by the dove tail cut on the gear dogs. Under heavy power it should be very difficult to pull it out of gear. If you have a problem with it coming out of gear, look at the engagement dogs on you gears. Whirlaways require a different cut on the dogs so that they can ratchet, and is the reason they require a locking handle.
    Norcal-Santa Rosa
    Well, I tightened up the adjustment on the spring and ball bearing, and the handle wouldn't move any more. so I took it apart and found some one had taken out the steel ball bearing and put in a PLASTIC one!!! It was about 3/8" diameter. I assume this is not right. What is the normal diameter of the steel ball that goes in there? Holy crap...
    Gone
    Sparks, Nevada
    Because you bottomed the adjuster out. 3/8 sounds about right.
    Norcal-Santa Rosa
    3/8 is right. The plastic ball that was in there was actually closer to 1/2". Took me awile to figure out the ball should be INSIDE the adjuster bolt 'cause thats not how it was when I got it-also the end of the bolt was messed up and the 3/8 ball didn't fit into it until I dressed up the end of the bolt.works good now.
    One more thing- do I need to fill the in/out housing with oil, it was about half full when I pulled off the cover.or does it draw what it needs from the rest of the box?
    California
    I'm pretty positive the proper way to adjust this is to bottom out the adjuster then take it back about 1/2 a turn or so. hope this helps
