exhaust adaptor plate help
Results 1 to 7 of 7
    Senior Member Scapegoat's Avatar
    SoCal
    Default exhaust adaptor plate help
    I need to have a set of adaptors created. I would need to have them ported from the exhaust port style of the head to the port style of the header.
    Heads are a 32 valve 5.4 lincoln
    headers are for the expedition motor.
    any help or guidance appreciated.
    i'm back!! 1QuickCP's Avatar
    Montana
    Any good machine shop could do it, id just carve them out of billet and hand port to finish. One MAJOR problem...thats one off prototype stuff.we did this all the time and there is no quote. its 100.00 a hour design and machine time and its however long it takes...so...hang on to your shorts as these jobs are always a pain in the a$$ for the shop...you learn not to take these jobs at all after a while...lol...
    but yeah if you were closer id make them at my shop at home..fun hobby winter project for holiday cash.
    LaGrange GA
    I'd try and find a common set of headers that have roughly the same spacing as your Ford engine's ports. If you can find a set that will cover the exhaust ports you're almost home free. With any luck all it'd take is some new holes on the header flanges.
    Montana
    Quote Originally Posted by earlbrown View Post
    good idea..or buy flanges and get headers close to it and wack the tubes off bend to fit and re weld
    Doesn't the Lincoln Navigator have the 32v engine? Maybe not headers, but you could get a set of manifolds from one of those that might work in an Expedition. The cast manifolds on all these newer engines are very effecient and well made.
    Just a thought.
    SoCal
    yes the lincoln has a 32v, the first year or two I believe did not. anyways a shop sold me some shorty headers that don't match my heads. looking to remedy the situation.
    Nov 2008
    Orangevale CA
    Quote Originally Posted by Scapegoat View Post
    What are these header's going in ? ........Eric
