Chiller plumbing
Results 1 to 7 of 7
Chiller plumbing
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Chiller plumbing
    I'm installing a chiller in my 21' Daytona (jet application). I want to know if the lone water supply off the pump (Dominator) is enough volume for my engine, jacketed headers, and a chiller ? I really don't want to add any more holes to the hull unless nessesary. I'm hoping to use the existing supply line, but not sure if it's got enough volume ?
    okie, lake Texoma
    Quote Originally Posted by DaytonaTunnel View Post
    Hey man, I run a stage five intercooler , water jacketed exhaust, and still have to run a bypass to keep the press. down. I tell you now that single tap puts out plenty of volume and press. to take care of anything that you want to do. You'll still want to run a bypass or a regulator to keep the pressure under controll or you'll have head gasket problems or blow your intercooler up.
    The Great Humongous P-Money's Avatar
    South Central WI
    I just force feed mine off the back of the boat. -16 in, two -12s out. No pressure valves.
    Silverdale, Washington
    Right on Droppy. Glad to see you're gonna get that mounted up
    MI
    Why not use the water that is getting dumped overboard from the pressure relief valve?
    They don't take a ton of water. Bigger concern is getting the h2o out. I have one exit line with no pressure relief, and another with.
    Darrell.
    Enumclaw, WA
    I don't want to use clamshell's if at all possible. Like I stated in my question, no added holes in the boat.
    I have solved the water getting out of the chiller problem. I plan on welding in some bungs near the end of Lightnings. This should make getting the water out of the chiller neat and efficient. Most important question I have, is 1 water inlet going to supply enough volume ? DMOORE, you said they don't need much water, I've been told differently ??? But I have no idea, as this will be my 1st chiller.
