s475 to s480 conversion info
Results 1 to 1 of 1
    Default s475 to s480 conversion info
    gonna post this here for later info since this is the boost tech section
    Borg Warner S400w/75mm compressor wheel 1.32 A/R exhaust
    Turbo Specs:Compressor Wheel Inducer/Exducer 75mm x 100mm
    Turbine Wheel Inducer/Exducer 96mm x 87mm
    Turbine Outlet 5 Inch V-Band
    Turbine Inlet T6 Divided
    Turbine A/R - 1.32
    Horsepower Rating 500-1050
    Borg Warner S400 w/80mm upgrade compressor wheel 1.32 A/R exhaust. Standard cover
    Turbo Specs:
    Compressor Wheel Inducer/Exducer 80mm x 109mm
    Turbine A/R - 1.32
    Horsepower Rating 500-1300
    Borg Warner S400w/88mm compressor wheel 1.32 A/R exhaust
    Turbo Specs:
    Compressor Wheel Inducer/Exducer 88mm x 118mm
    Turbine A/R - 1.32
    Horsepower Rating 550-1400+
    anybody notice that the ex is the same between the 75 and 88mm? put a 88mm wheel and housing on your s475 and have a 88mm
