Best reusable header gasket(and best silly cone)
Results 1 to 14 of 28
    Default Best reusable header gasket(and best silly cone)
    I just bought some copper exhaust gaskets from jegs for 25.99, that's as cheap as I can get the metal oe ones for a rect. port chevy. I dunno ..now that it's too late...what would you guys run? My passenger side bassett must be tweaked good. I'll try to edit in a pic or 2 when the camera charges. If the copper doesn't fly, what flavor silly cone do I use.... the redish orange high temp perma tack?? Yes I'm going to try the best to fix the warpage the best I can with the funds I have to work with(none but a file). I know this question isn't quite along the cerebral lines of the turbo thread The silicone sounds great if it would work, it also sounds like a pia for as many times as I swap headers.
    The redhi temp or the copper stuff will work. Don't even try the coppper gasket without some silicon. But don't think that the silicone is going to get you out of a badly warped header flange. The exhaust can blow that stuff out just as easy as standard header gasket material. Sometimes you are actually better off with 2 standard type gaskets on a warped flange. If you know there is a dip in the flange, like the center two ports, cut the flange to seperate it from the other pipes, it so that portion can pull down flat. Better than constantly blowing gaskets.
    Cantard 71hallett's Avatar
    snow bank
    x2 The ones that come in an engine kit or for stock type manifolds Kreg.
    Permatex Ultra Copper or Ultra Black:
    http://www.permatex.com/products/Aut...sket_Maker.htm
    Both work great and I don't ever recall a blow-out even run after run on the Nos. Great stuff.
    Put a bead on and let it set-up a bit then bolt it down.
    S CP
    Senior Member TurboNova's Avatar
    Dec 2009
    Lake Havasu City AZ
    Try these gaskets, I had the copper gaskets but went to these. They are thick but smash down when you tighten them. Great for headers that are not quite straight. They are also coated with graphite. Even better no silicone. I have used a bunch of these on turbo engines and na headers too.
    http://www.remflex.com/
    California
    Although not cheap and only somewhat reusable, I always thought Earls pressure master were a pretty trick set of gaskets. I ran these style on my street car (aluminum heads and headers) no leaks and i never turned a wrench.
    http://www.summitracing.com/parts/EAR-29D04BERL/
    ......wow these have gone up in price($39.99) since '01, but if your chasing an annoying leak it may be worth it
    Thanks for the suggestions guys, I may split he flange between cylinders. Here is a pic that shows the blow by. Keep in mind I used these gaskets.......alot.lol
    El Cajon , Ca
    I sell a TON of these at work on a regular basis! No one has ever complained , or came back , and i sell them to people who constantly blow out gaskets.
    http://store.atechmotorsports.com/pa...5&autoview=sku
    Everybody has a favorite gasket that works for them. But if your flanges are jacked up, a tube of silicone on a stack off copper, or mineral gasket isn't going to save your ass. The biggest problem have found with most headers out there is the flanges are too thin and warp over time. A good header should have a 3/8 flange, and most have a 5/16 or even 1/4 flange.
    Kingman/Golden Vly, Az
    on the subject of the above gaskets mentioned...can they be used with logs? or is there another way to go!
    FastRat
    Looks like the wrong port design gasket, The bassett headers have a pretty big opening on them, probly bigger than the square port gasket can manage to seal.
    The bassetts are roundish and the ports on my brodix heads are more square, I assume you all can see the 2 burnt spots(leaks) on both the gasket and the corresponding cylinders. I'll edit in a pic,the headers are larger than exhaust ports on the heads..if that makes sense.
    To me it appears they are burning out the corners. The ex ports appear to be D ports, I think the round gaskets would work fine, something closer to the header opening would crush /seal better.
    Silverdale, Washington
    Actually Kreg you have brought up a great question. Which is better, a gasket that is closer to the diameter of the port or one that is closer to the diameter of the exhaust.
    In my case, Chev iron heads (classic 990 style) and Borla 2 1/4" headers...
    Thanks a bunch..........john
