Fuel Regulator question
Results 1 to 14 of 15
    Redding, CA
    Default Fuel Regulator question
    Thanks in advance guys!!
    I have a new Aeromotive A2000 pump at 18lb. 10AN from tank to Reg. 8AN bypass to tank.
    2 1080 Dominators' withe 6AN feeds.
    Engine is pretty mild, BBC, 700 HP at the outside. I realize this is way overkill on the pump, but I got a good deal from a PB Member on it.
    I am trying to pick out a 4 way regulator with 10AN O-ring in, 4x6AN o-ring out with guage hole.
    There are several Aeromotive and Magnafuel ones with all these features.
    Some are "Boost Control".
    These are more expensive. They range from around $200.00 to $275.00.
    What does this do, and do I need it?
    Which Reg is the one I want??
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    13202 aeromotive and never look back, if its not turbo you really don't have to 1:1 ratio the regulator unless its getting lean up top.
    Never over look this one. Hnads down the best regulator I have ever used for the buck!
    http://www.jegs.com/webapp/wcs/store...-1&showValue=1
    It's the same one Steelcomp used on this blown 496.
    Cantard 71hallett's Avatar
    snow bank
    Do yourself and your pump a favour and make sure you get a bypass reg.
    This is true. Those Aeromotive Electrics do like to see the fuel in constant motion. Damn I hate electric pumps. Almost as much as magnitos
    snow bank
    Yes...this is true.
    Redding, CA
    Even with the bypass on the pump?
    Tommy
    Redding, CA
    I always thought that EITHER the pump or the Reg. needed the bypass.
    Should I have a bypass Reg. with a bypass pump??
    Tommy
    Mohave Valley/Quartzsite
    I don't have a bypass regulator and I've never experienced any issues. My stuff if BG but I don't think that makes a difference..
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    okie, lake Texoma
    shouldnt need to if you bypass at the pump
    H8-2-W8
    [email protected] first pass
    I was thinking of the aero 1000 pump. The 2000 isn't fuel over motor pump. It has a seperate motor and pump section with an internal bypass like an oil pump. Any four port non bypass reg. will work fine. I still like the Holley.
    Redding, CA
    Thanks Guys!!
    Tommy
    if you get the 13202, block the bypass at the pump i'm doin the same to my prostar 500 magnaflow pump. the 13202 is a bypass regulator and will handle any pump you put to it i'd much rather have a shitload of volume goin thru my regulator than bypassing at the pump, but that's me
    Redding, CA
    if you get the 13202, block the bypass at the pump i'm doin the same to my prostar 500 magnafuel pump. the 13202 is a bypass regulator and will handle any pump you put to it i'd much rather have a shitload of volume goin thru my regulator than bypassing at the pump, but that's me
    Thanks!! That was my next question!
    Tommy
