Fuel Efficiency
Results 1 to 14 of 30
Fuel Efficiency
    Ladera Ranch
    Default Fuel Efficiency
    Curious to get some input on what you all think a set of dual carbs would do to my fuel spending. Id make more power so I expect to use more gas. Question is how much more gas & power? Motor is a 548 with a HP950, wilson ported Victor jr. Currently making 800 @ 6200 rpm in a jetboat.
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    If I remember right, Futs had a dual carb/tunnel deal and changed over to a single carb, on that Southwind cruiser he is selling. Maybe pm him. Also, Sleeper CP might have some experience w/ this ????
    Steady Rollin
    Corona
    This is a pretty solid topic at these times.
    I'm currently debating which way to go on the repower of my v-drive cruiser. I'm currently going between single carb N/A, and dual carb turbo.
    I'd love to hear some real world stories
    cfm
    cfm is offline
    If you are really making 800hp with a 815cfm carb on a worked over Vic JR I would say you would make 60-80hp or so more with something like a Dart Tunnel Ram and guru worked carbs. At the same time, I'd say 35-40hp more with a Victor 454R or Super Vic with a 1050.
    Remember, a Holley 950 is really just a 750 main body on top of an 850 base plate.
    cfm
    cfm is offline
    Ooops. Just noticed you said 548", which must be a Ford. I assumed Chevy. So schit can the Dart Tunnel Ram, but use the info I said above with a Ford equivalent to the Dart Tunnel Ram.
    I say you put a nice fogger on it and keep your current bad a$$ set up. A tunnel ram, another carb, and a possible cam swap...to really see a hp increase sounds like alot of coin. Then you get it at the pump everytime too, w/ those thirsty carbs. imo
    Ps- thanks alot for the wiring tips, it turned out killer !
    East Side
    I'm in the same boat debating switching to dual carbs. I would like to hear from someone with some real world experience as well.
    It's interesting, do you have some Data to go along with your (estimation) of power,or
    torque. and at what RPM. I personally have never seen 60 or 80 or anything close
    with tunnel ram vs. a single 1x4,,, runner length as well as available CFM are both to be considered
    TEN THIRTY ONE RCB19's Avatar
    Quote Originally Posted by Steve Brule' View Post
    What's going on Steve? I see you found us.
    RCB
    B1 Racing cs19's Avatar
    Default Brule Racing
    Good to see you posting over here Steve!
    B1Racing.net
    Senior Member hotbo's Avatar
    lake Ouachita AR
    single carb it dominator set-up right just imo they are great and get good fuel consumption
    i by no means am a t-ram fan all about looks imo.but then again chris runs a single carb and his boat seems to run like a bat outta hell form what i here and see.so go figure
    good luck and whatever you choose i hope yu might a good choice and it works for ya,travis
    Ladera Ranch
    Hi Steve,
    I think you might have some data on it, you dynoed the motor. It was a DNE motor, made 800 @ 6200 rpm, made 825 @ 6800. Dynoed in January of 2007(I think)
    Intake is a victor Jr that we sent to Wilson to have hogged out. Spent 2k on porting. Considering the amount of money I have in the singel four Im wondering what the advantage would be of going to the tunnel ram. Im sure I might see a bit more in the upper RPM range.
    Im turning a Heritage A impeller to 5800 which according to Jack takes about 775hp, which is right inline with my dyno #'s.
    Im wondering if a bigger carb might get me some more R's...? Or maybe the tunnel ram is the way to go-but only if I could re-coup some of my investment in the V-jr.
    Ladera Ranch
    Quote Originally Posted by 76Miller View Post
    Glad I could help on the wiring. Getting ready to do my dads boat. One of those often overlooked things.
    I may go with the NOS. Motor is ready for it, just wanted to up the power a little more if it wouldn't be too pricey. I've got a lot into the single four sleeper setup so I figured if I found a buyer I could finance the tunnel ram that way.
    Sounds like NOS is best way to go. Im probably going to wait until I come across a dominator suction housing though.
    Ladera Ranch
    Its a Chevrolet 548.
