line boring ???.....
Results 1 to 14 of 73
    Kingman/Golden Vly, Az
    Default line boring ???.....
    Pls explain... what has to be done in order to line bore a block?...do u have to torque the caps down?...does it chng the bearing size on the mains of the crank?...is it absolutely necessary when changeing caps?...all info appreciated
    thnx
    FastRat
    thnx
    FastRat
    First, yes it is absolutly necessary when any cap not originally on THAT block is changed. Period, no question!!! Yes the caps are torqued to spec with the EXACT same type of fastners you plan to use. Studs, ARP bolts, stock bolts, etc. First the face of the cap is ground a couple thousands (or more if needed) to get it FLAT and SQUARE to the bearing bore. Now the hole is no longer round due to this. Then he machines it round by honing it, or boringif it was way off or the bearing bores where damaged. If he does it right, he will make constent checks to see how the hone is cutting, and may loosen a cap alittle to adust the way the hone is cutting a peticular saddle. When done, your bore are perfectly inline and dead perpindicular to the cylinder bores and parrallel to the deck. And the diameter will hopefully be on the tight side of the stock specs and thery DO NOT require special bearings This is the over simplified explanation, but it no simple task, and for the bad news, 1 in maybe 5 machinists that perform align hone a block know what the flock they are doing.
    X2! plus caps are matched from the factory and any change requires this.
    Gone
    Sparks, Nevada
    "and for the bad news, 1 in maybe 5 machinists that perform align hone a block know what the flock they are doing."
    Amen to that.
    Why not bigger saddle dia. for the bearings, rather than cut the bore, and move everything north? I know how it's done, but the internals all get moved in the process.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You loose the bearing crush if you just open up the bore. And line "BORE" would remove a lot of material then you have to hone it afterwards The bore tooling is supported on each end. You can manipulate the center of the cut.The hone just follows the existing bore.
    What you gain by moving the rotating assembly is worth it. It would be a lot of work to cut the caps and machine the registers to end up with the main bore in the same location when you are done.
    We don't cut the caps when we do the high end aluminum blocks. It r,moves the anodiizing from them. We sand the registers to close up the hole before honing.
    QE 439 Twin Turbo
    BBig difference between align boring, and align honing...
    Hat
    Hat is offline
    Jan 2010
    thnx
    FastRat
    Line boring consists of cutting the main caps on a grinder (special) to ensure the ground surface is paralell to the bore about .005 and reboring the hole to the original size, the only times that process is usually used now is to size new caps to an old block, like aftermarket caps, then when a size around .002" small is achieved the block is then line honed to achieve much better finish, and results, a good hone operator can hold .0002" from end to end on a 7 main 6 cylinder, and the same tolerance with a 5 Main V8.
    a good line bore tech should go for .000 at the block leave .002 to hone, thereby moving the crank up in the block a minimum amount
    I remember one team I worked for decided they were tired of taking the mains out of the blocks and instead, built replaceable inserts. They machined the block oversized and installed the inserts. (Alum block) I got the job of building the boring bar system so they could replace and machine new inserts in the block right at the track.
    Default Block material
    If done correctly, the block will not lose any material. (assuming it was straight before you started). As mentioned, finding someone with the knowledge and equipment to line hone a block is tough. 4 out of 5 will make it worse. IMO, the shorter timing chain sets are proof some body screwed up and moved the main bore too close to the camshaft. This can't be a good thing if the bore was moved that far unless the crank C/L to cylinder perpendicularity was way off to begin with............Original stock caps on a block are usually damn close and IMO, better left alone unless there is an obvious problem. Replacement caps must be bored/honed to size and alignment, and held to .XXX to camshaft C/L parallelism and location....Ray
    LOUD BOATS SAVE LIVES
    So you spin a main, just toss the motor? Just thinking...why not bigger o.d. bearing shells, same I.D. not cost effective?
    Default Spun main?
    I don't know. I've never spun A main bearing. I've wiped out all of them, but never just one. I didn't spin any, but the block saddles got so hot I was afraid of it......
    I imagine there is a "fix" to save the block, but all I've seen were scraped because like you said, "cost effective" vs starting over with another block.....
    Ray
    Senior Member lbhsbz's Avatar
    Long Beach
    Crap like this is why I always seem to go through 3 or 4 core blocks before I find one I'm happy with.
    I've had 2 blocks that one of the main caps twisted on and locked up the crank when studs were used...problem wasn't there with the stock bolts. Both of them are already bored and honed when I find this out.
    I'm getting kinda tired of it, but I'm not happy with the solution either...becuase line boring involves an interupted cut with very little material removal and no room for error, which means more likely than not, it'll get screwed up. Seems the price you pay to fix a block right any more...you could by a new dart block instead, but are they even straight?
    Default Straight?
    I worked in a shop that measured down to Millionths. Our stuff wasn't "perfect" even at that, but we called it "Adequate" for the task it was made for. Good word, Adequate........ What I mean is, how straight is straight enough?...........Ray
