Blower build Info needed
Results 1 to 14 of 59
    Senior Member sturat's Avatar
    Houston TX
    Default Blower build Info needed
    Ok looks like i am going to go the blown route. Now the questions really start for me.
    Here is what i am thinking of doing, just do not know the path to take.
    496 BBC with a 8-71
    I have a gen 4 HP block to start with, I also have a set of Dart Pro 325 heads to go with it. What do i do from here.
    Need info to give the Machine shop. This build will take some time for money reasons but i want to lay out my path and start gathering parts for my goal.
    This is going in a shovel nose ski hydro. Not looking to be the fastest boat on the river but a cool hot rod.
    Legalize the Constitution!
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Quote Originally Posted by sturat View Post
    496 BBC with a 8-71
    spend more money
    [/SIGPIC]
    Houston TX
    Quote Originally Posted by Lucky View Post
    spend more money
    only live once
    Gone
    Sparks, Nevada
    so you have what pieces now?
    You said 4 bolt block.
    Crank?
    etc?
    Hat
    Hat is offline
    Jan 2010
    496 BBC with a 8-71
    what fuel do you plan on running ?.....how much power you looking at ?
    Houston TX
    Quote Originally Posted by Hat View Post
    I am on the fence will the fuel deal. Really thinking hard about using alky but not 100% on that. I am not super keen on the idea of taking fuel with me. I like being able to pull up and fill up with 93
    I am looking to get somewhere in the 800-900 range
    Houston TX
    Crank?
    etc?
    I have a bare block and the heads that is it.. Long long road ahead
    i'm back!! 1QuickCP's Avatar
    Montana
    l if ur really thinking alcohol and HP you better really need to get a better block, stock gen 4 4 bolt will have problems, maincaps walking, cracking in lifter valley,cracks in rear,ect ect etc...oh and with out adding the extra headbolts sealing becomes a issue as well.
    I guess the question would be what kind of HP are you lookin at?? 800?, 1000? or 2000?
    Houston TX
    Quote Originally Posted by 1QuickCP View Post
    800-900. This will not be a race boat just want a peppy lake boak
    That looks good and runs a little too.
    Can't cure stupid 1Homeblown's Avatar
    Sep 2008
    Torrance, Ca.
    Default Rods!!
    I have a set of rods for you if you haven't gotten pistons yet!! American made!! Here's the link:
    http://www.performanceboats.com//showthread.php?t=37461
    Houston TX
    home
    thanks i will keep them in mind
    Hat
    Hat is offline
    Jan 2010
    I dont see any compression over 8.5 if you have a decent blower and less than 32 in the Mag, I dont like cheap fuel deals, alky is the best, you may not get much mileage but you are WAY less likely to hurt a bunch of expensive parts, the choice is yours, go with Alky, and Up the compression if not, you have to kill the compression or the engine will murder itsealf, and on 93, it'll never come close to what it runs with alky
    Houston TX
    Seems like this is the way to go. Do i need to do anything extra to the block? What compression should i run on Alky with an 8-71?
    Hat
    Hat is offline
    Jan 2010
    10:1 is safe, you can run some decent boost, like 20-30% over and not worry at all, just depends
    I would look into putting some filler in the block if it's a big bore deal to thin a cylinder wall isnt good you might have it sonic tested to see if the walls are good, no core shift....
