ebay built 1500hp bbc turbo motor for beginners
Results 1 to 14 of 25
    Default ebay built 1500hp bbc turbo motor for beginners
    you guys do the math, i'll build the system on paper and let's compared 1500hp/1500ftlbs to each other:
    pair of these ic's for 400.00 , which is wayyyy overkill and will make super low iats! expect 70* iat's with ics this big on a bbc:
    850 quickfuel ban blow thru purpose built carb straight from qft bout 700.00
    http://cgi.ebay.com/ebaymotors/Quick...item518fc3df2e
    fuel pump to feed the blow thru carb, this 1 is overkill but that's a good thing , the pump works, i know and have talked to guys running it, obx belt drive 179.00 :
    http://cgi.ebay.com/ebaymotors/OBX-E...item2a03e0e8cd
    13202 regulator, the top diggy dog in blow thru fuel pressure control! 159.00
    http://cgi.ebay.com/ebaymotors/Aerom...item5638c3b92b
    pair of s475 turbs that will produce up to 2200hp and ftlbs, 1250.00:
    http://cgi.ebay.com/ebaymotors/Genui...item1e59e550b7
    great CHEAP wastegate we've been having great luck with and its huge, plenty to realllllly control boost! 160.00 a pair, fully ss other than valve head!
    http://cgi.ebay.com/ebaymotors/60MM-...item58856d0264
    50mm blow off that works great, copy of the tial q valve basically but 1/4 the price! 50.00
    http://cgi.ebay.com/ebaymotors/51MM-...Q5fAccessories
    carb hat, can be picked up used for around 150.00ish i like the ev pro hat or the csu hat, they're both really tall and the taller the better, its straightens boost flow thru the carb and makes tuning a breeze
    buy a set of unchained ss headers from mark for around 1650.00 new, badassssss headers!!!!
    13202 aeromotive regulator from ebay new :159.00 bucks
    ok, that's at least 1500hp set-up right there built from ebay, suxxxx on dattttt
ID:	64508   Click image for larger version.
ID:	64509   Click image for larger version.
ID:	64510   Click image for larger version.
    okie, lake Texoma
    the first three pics are red x's
    H8-2-W8
    [email protected] first pass
    good thing i provide links then it's the x02 2000hp intercooler:
ID:	64512   Click image for larger version.
ID:	64513   Click image for larger version.
    4859 is what i came up with. if someone wanted to upgrade the carb later on, this same system will put down anywhere from 1800-2000hp depending on the longblock its on. c&s makes alot of different carbs, 1600.00 buck for that carb isn't horrible considering its almost 90% tuned in when ya get it the qft 700buck carb will be alil fat at wot, but that's nothing some hsab changes won't cure the qft carb is limited by the fuel bowl volume, put some dual needle and seat bowls on it and for 1100 total it'd prob do 1800hp pretty easy.
    Was kinda hoping this thread would take off. OK, so $4859 + a decent long block will get you 1500 HP. Does that include all the plumbing/bracketry to install it? If not, how much does that add?
    coldside plumbing stuff is pretty cheap man, figure bout 200ish for piping/silicone couplers/t clamps. the turb braces are custom made, you'll have to fab those up. the stuff i posted up isn't the best stuff, its just stuff i've personally either used or know someone 1sthand that has. it all works, even though some of the stuff is cheap. none of the things that matter are though
    New here Beer:30's Avatar
    Bakersfield, CA
    BTW, how about an update on your LS1 build - either here or on the orig thread or PM. Or, maybe you updated and I missed it?
    Anyway, on this hat, is the top port just for boost gauge probably? or do you blow some water/meth in there for added cooling???
    EDIT: I guess it would actually be more for plumbing to the wg(s), fp regulator(s) and such that are boost-referenced.
    that's the blow off valve, the top port is the only connection to be made to it, you just hook it up to manifold vaccuum. when the motor is in boost, the blow off valve stays shut and when you chop off the throttle, the intake goes into vaccuum which in turns sends a vaccuum signal to the blow off valve and opens it, venting boost to atmosphere.
    yeah, i've updated the mighty mouse thread recently, bout it.got tired of the naysayers saying its not gonna work, so i've had the "watch me" attitude about that project
    http://www.performanceboats.com//sho...t=52306&page=5
    Senior Member hotbo's Avatar
    lake Ouachita AR
    all of those parts look pretty damn good to me
    thats not alot of money for the power ratio.
    so what kinda mill would you go with?
    Heads,Cam and so forth,that stuff adds alot to the price
    decent alum heads and a off the shelf turbo cam that peaks whereever ya want it to would be fine, it doesn't take much of long block to get to 1600-1800hp with turbos, the shock just isn't there like nitrous or blown.you can look at mark's dyno pulls and see where he ran outta cam, if he had more cam it would've kept pulling. we cammed billy's 496 to pull to 7500 peak, just a lunati turbo cam with dart pro1 345cc heads.
    Bakersfield, CA
    Ah. I thought it was listed saying hat.
    I thought it looked kinda small, although hard to scale it without something to reference next to it.
    lake Ouachita AR
    okay would a say 468 bbc with some iron heads make any power.
    say the heads were 781s with the normal bigger valves,bowl work only and port matched to the intake.
    tall single plain dart or victor.
    turbo cam.
    what kinda power would that produce,im sure heads would hurt it?
    Bakersfield, CA
    turbo cam.
    Impatient will have much more insight, but I can tell you that turbocharging pretty much ANY combination will add significant HP/TQ. Look at the Buick V6s. Nothing special. No AL heads or anything. Any type of boost adds HP, however slight. That is just simple VE (volumetric efficiency). Doing it SAFELY is the key. Plenty of fuel and very accurate ignition timing. Intercooling as well.
    The other reason turbos SPECIFICALLY add significant HP/TQ is the fact that they don't require ANY power to drive. Supercharging, while still great, REQUIREs power to drive them.
    that about says it all. alum heads are more for weight and modern design etc.. but cast will get er done too.
