Carb recommendation
Results 1 to 14 of 26
Carb recommendation
    Lago Vista, TX
    Default Carb recommendation
    I have a new Dart 9.8 deck 509 short block with eagle/srp internals, Clevite H bearings, Victor Jr intake. I dont have heads yet but am considering AFR 305's. Looking to spin around 5000 rpm or so, prob 600HP. What is the recommended carb. I have a Demon 850 in the garage but want to see what ya'll think. Thanks, Dave
    2006 Advantage 28 Sport Cat BR
    Lake Travis
    Austin, Texas
    Fresyes
    I've got a pump gas 565 and I'm running a Dom 1050. Very mello. Not over carbed at all.
    Maybe your 850'll work because you wanna keep the R's down, but I have my doubts.
    Is it just me or are toilet seats getting smaller?
    Nov 2008
    Orangevale CA
    Quote Originally Posted by freakdave View Post
    The 850 should run you up to 5760 rpm -at 100% efficiency,, should work fine.................E
    Lago Vista, TX
    cool, thanks
    Lake Travis
    Austin, Texas
    Dave, let that motor spin. 6000rpm's on a hyd cam is no problem these days. Your motor will thank you. Plus it's 1000 more rpm to prop for.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    850 will work. 1050 will make more power.
    cfm
    cfm is offline
    BG850 should flow more than a Holley 850....so I'm told.
    Either way, the 850 should be more than adequate as long as it is tuned correctly.
    5325, you really like the Dom's huh ?
    cfm
    cfm is offline
    Oh, wy limit yourself to 5k ? Your missing out on a lot of power and the potential of the AFR's. Go atleast to high 5k's.........you'll be thankful you did.
    Lago Vista, TX
    Thanks for all the input. Mid to high fives is prob what the engine will twist. Now i just need some money$$ !!
    Lake Travis
    Austin, Texas
    Nov 2008
    Orangevale CA
    X2,.....on the money, lol........E
    Yup. The last 496's ran on the dyno with both. I forget the gain, but the Dominator crushed teh 850 in power. and teh boat starts like it has EFI
    IMO any decent Big Block needs a Dom. A well setup Dom with annulars can out low end an 850 and bury it on the top. Problem becomes, which manifold. At 5000-5500 in big boat, it really doesn't want a single plane. Why Edelbrock discontinued the Dom dual plane I will never know. Probably needed the space and line time for 409 and Buick heads
    cfm
    cfm is offline
    I disagree when referencing a minimum of 496cid, modern HR, and good modern heads.
    Lower cid or low lift cam or OEM heads and the dual plane is usually better in that rpm range.
    Tri-Cities, TN
    You've got the 850 so run it. AFR 305 heads are a good choice for a mill like this. I agree with the others I would spin it to around 5800 or so, you have a solid bottom end and married to a set of AFR305s and a hyd roller you can reach your goal.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
