clearance problem
Results 1 to 14 of 21
clearance problem
    WHITTIER CA
    Default clearance problem
    I AM putting together a blown 496 just a river play boat, as i am putting to bottom end together i have encountered a problem and i need some advice. My rod clearances are between .024 & .027 and all of my books say that should be between .016 & .020..... New eagle rods that are resized and new eagle crank. Whats the opinion........
    1. Do i leave it and let it run?
    2. To i try and fix it and how?
    3. Do i send the rods back and try another set?
    Quote Originally Posted by scsriverrat View Post
    i am putting together a blown 496 just a river play boat, as i am putting to bottom end together i have encountered a problem and i need some advice. My rod clearances are between .024 & .027 and all of my books say that should be between .016 & .020..... New eagle rods that are resized and new eagle crank. Whats the opinion........
    run it!!!!And why do you think its in the rods?
    WHITTIER CA
    Your right it could be the crank. Either way you say run it?
    I know I am throwing myself under the bus with the sticklers on these boards, but I run anything over .0025 and under .003. I just don't loose sleep over it.
    x2
    x3
    Lurker
    NC
    Talking Thread Jack!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I generally target mains at .0035 and rods .0027
    And I've found eagle cranks to be to the big and require HX bearings rods all over the place and small ends needing honed.
    QE 439 Twin Turbo
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    So ya dont have to type it twice, http://www.yellowbullet.com/forum/sh...d.php?t=208332
    WHITTIER CA
    Thanks for the advice it put me at ease i will now check all journals for bearing clearance instead of spot checking. I did have all of the rods resized before in installed them ...
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    This is what i did to try to squeeze down the clearance spread.
    I mic'd all my journals, i then took the largest journal and set my dial bore gauge. Went through a measured all my rods and then starting mixing and matchings rods. I put all my tighter rods on my smaller journals, in the end i had 6 rods at .0023, 1 rod at .0022 and 1 rod at .0021.
    That's not really a thread hi-jack, but more like a short break for a word from our sponser.
    Lurker
    NC
    Quote Originally Posted by NORDIC454 View Post
    Wasn't gonna go there!
    okie, lake Texoma
    You better watch it Warp, from what I've heard, getting it in the can will make your hair fall out
    H8-2-W8
    [email protected] first pass
