Carb linkage
Results 1 to 14 of 18
Carb linkage
    Whitewright, TX
    Default Carb linkage
    carb linkage
    [Hi Dave,
    I Have the same carb to blower adapter like you have. I put my carbs on there and have a 12 1/8" center to center for my inline linkage. (problem) I can not find that linkage any where that has that 12'' size linkage.
    Where did you get yours from? Your's must be even longer.
    Thanks Bud, Troy]
    Troy,
    Here's a pic of my linkage. Mine is 12 11/16" c-c with only 1/16" between the bowls. Mine just consists of a flat plate to mount the throttle cable clip, a piece of steel rod with swivel Heim ends on each end for adjustment to connect the two carbs. You can make all this stuff yourself and get the Heim ends at a good hardware store. Dave
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Thank you. I really like this set up. It's clean and easy.
    Troy , Simple and easy ,kits are for side by's and in lines as I recall we bought it from the Blower shop I'll PM you some info tommorow
    Kingman/Golden Vly, Az
    u can buy the hex rod any length & heim fittings from Enderle Fuel Inj in Calif...they are pretty reasonable ...much cheaper than The Blower Shop!...just sayin'
    FastRat
    Whitewright, TX
    Default Hex rod
    FastRat's right. The hex rod is even better. It thicker and aluminum, has female threads for the heim ends. Jocko
    spokane, WA
    Any reason some of you guys like to run the carb's inline vs sideways? Is it just because of the linkage or is there an advantage to one? Maybe the way they feed the blower??
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    Derby, Kansas
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    I run mine sideways on my tunnel ram to make jet changes easier. Who wants to pull a carb just so you can change jetting?
    Whitewright, TX
    Travis
    I agree, it is easier to change jets with the carb's sideways, however once I have my jetting dialed (for a lake boat) it seems they rarely have to be changed again. If so, I can have that one carb off in about 3 minutes. When mounted in-line, I do like the simplicity of the linkage (substantially cheaper), the routing of the throttle cable under the motor and up from the rear of the motor, plus simpler (again cheaper) carb bowl fuel lines.
    Jocko
    X2
    all the way around...much cheaper & easier if the situation allows!...just sayin'
    FastRat
    MAHTOMEDI,MN
    I think it's easyer with linkage, looks clean, less bends in the fuel line. Fuel comes up and in fuel log and straight into carbs not up and over and around. Thats just what I think.
    Lake Havasu az.
    Is there an advantage for having a push throttle?
    Sheriff Joe Arpaio
    Derby, Kansas
    Quote Originally Posted by APOLLO View Post
    Man I didn't think mine was that dirty
    Whitewright, TX
    Nice! Yes, that is a very sano setup. On a tunnel ram, the #107 linkage ($125.00) clears everything better and bolts right to the intake. On a blower you have to mess with spacers and stuff off the blower studs. PIA
    Jocko
    Derby, Kansas
    Jocko
    Thanks jocko I tried to keep it neat. That linkage was about $65 from Enderle and then the Morse cable holder was about $5 from Rex Marine. The throttle, regulator brackets and the top were custom made.
