BBF Dizzy
Results 1 to 14 of 22
BBF Dizzy
    Senior Member sturat's Avatar
    Houston TX
    Default BBF Dizzy
    I am trying to find out what is good budget dizzy for BBF. I do not want to pay 300.00 - 400.00 for one from MSD.
    This is going on the family boat and it is a stock 460. I do not want to run a box or points.
    What are your suggestions?
    Legalize the Constitution!
    Senior Member Amango's Avatar
    Sep 2009
    I have had good luck with one of this setups. PLUG and PLAY.
    http://www.summitracing.com/parts/PNX-D132810/
    1984 bbf 1 ton truck dizzy, they have a great mechanical advance and mag pickup in them, 60bucks reman from any parts store. i never buy msd dizzy's for bbf, always use that dizzy on stuff i build or help with. it'll have 3 wires coming outta it, the orange and purple hook right to a msd box
    Houston TX
    Can they be ran without a box? "ready to run"
    Quote Originally Posted by sturat View Post
    used 6a msd box can be found pretty easily for under a 100, i see them all the time. msd box failures imo are installer errors, some people just don't know how to properly connect wires in a marine enviroment. i've never had 1 of my boxes lay down on me, ever i've owned at least 10 of em of the yrs in dirt track cars,boats,autos etc. for under 180bucks you could have multispark, jus a suggestion normal ignition has hell firing fuel with water in it, which happens a lot on the lake, or get flooded 1 good time and she won't bust off
    Houston TX
    thanks for the help
    lol, right..... Devilman's Avatar
    South Texas
    You do anything to them, or run them right out of the box? I have one of those & may use it myself. The old Prestolite in there now has seen better days. Whats your thoughts on the Mallory Unilite dist.?
    Still liking MSD , we used to use unilites but had to many issues with the IR's We've used a few Petronics Marine units with OK success Just an OP
    San Francisco Bay Area
    Cool
    The Ford Motor Company electronic distributor, known as the DuraSpark electronic ignition system. The magnetic pickup coil and reluctor in the FoMoCo dizzys are the EXACT same ones used by MSD in their distributors, which is why MSD shows in their instructions how to hook up their MSD box to a Ford DuraSpark dizzy or MSD dizzy to a Ford box.
    • Remanufactured DuraSpark from your parts store: $60
    • Recurve Kit: $12
    • DuraSpark box from the local yard: $20
    The OEM distributors don't have shiit for advance curve, so the recurve kit is mandatory.
    We have known these setups to provide stable spark well past 7000 rpm and to support 2000 hp blown alcohol engines. If you want a freshly remanufacured/recurved DuraSpark dizzy that is pre-tested and ready to drop into your engine, just PM me and let me know.
    LO
    High Flow Dynamics
    Quote Originally Posted by LakesOnly View Post
    • Recurve Kit: $12
    LO
    paul knows what's up! very nice dizzy, even though its ugly as hell
    Quote Originally Posted by Devilman View Post
    i've ran them outta the box and took them apart to tack them locked, just depending on what i was helping with or building.the recurve makes em work alot better, but you can also just put in lighter springs so it gets to max timing faster, at least that's what i've done a couple times. i can remember a couple of times just dropping in from outta the box, ask jetboat steve, that's what i did to his
    South Texas
    I looked at those with the recurve job on LO's website once before. I bought a Mallory Unilite from someone here on the boards awhile back, but haven't ever used it. Its gonna be a bit before I do anything, either way about it.
    Orlando.FL
    E Bay BBF hei, Skip White $43.00 run good, guaranteed.
    mallory makes great fuel components, everything else, not so much i'd trust the factory dizzy over a mallory anyday.
