Will Gen 4 cams work on Gen 6 blocks?
Results 1 to 14 of 17
    NOSTALGIC V-DRIVES DIMARCO21's Avatar
    Nor Cal
    Question Will Gen 4 cams work on Gen 6 blocks?
    I have a Gen 4 cam for sale in the spam section. A question came up....will this work on my engine?
    Will a Gen 4 cam work on a Gen 6 block?
    Thanks.
    Nor Cal
    yes
    From what I understand the only differene is the timing gear bolt pattern in the end of the cam (smaller on a Gen6 to make room for the retaining ring)
    And it will also need a cam button because there is nothing retaing it cam anymore.
    Does that sound right?
    Thanks.
    Quote Originally Posted by DIMARCO21 View Post
    Thanks.
    That and a timing cover that will clear the MK IV timing set. I know the IMCO works well.
    X's 3 on the cams and just a side note , with a little machining effort and some finese' the Gen5 timing cover will work succesfully on the Gen 6 Tom
    member
    Nov 2008
    Will you elaborate on this for me Tom? Gen 6 only has six bolts for the timing cover. Thanks SJ
    Quote Originally Posted by super junk View Post
    The locater dowels are dead nuts on , two bolts are in perfect position , 4 need to have the holes slightly elongated and the periferal stiffener ridge flattened out a smidge, all bolts are sufficinatly spaced to provide a good seal , Just a quick expireiment for curiositys sake Tom
    member
    Nov 2008
    Good info, is the 5 cover deeper than the six? What material is it made of? As always you are the man. SJ
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    mk5 cover looks just like the mk4 but with a mk6 pan seal
    QE 439 Twin Turbo
    member
    Nov 2008
    Good deal does it seal with a gasket or o-ring, prolly gasket. Thanks for the info. Info
    Josh just fabbed this for me on a "6" block replacing a "5" block , the "pinch" was customer budjet The deep "5" stamped steel deal will handle a double roller the, "6" cast unit (w/oring) won't (too shallow) , the "5" uses a gasket (or Right stuff) The Pan arch's are the same uses the same one piece "unigasket" (common to 5&6) Tom
    SJ I took a pic for ya today ...
    member
    Nov 2008
    Thanks Tom. That opens alot of options for this type of deal. The only covers deep enough for a double roller on a six were the CP or Milodon that I Knew of. I have the CP cover on my deal and the polishing made the timing pointer to rounded for my taste. I have been thinking about milling the pointer off and installing an adjustable pointer on it. SJ
    LAID IN MEXICO
    santa paula, ca
    Default cam
    my gen 6 had a mark4 cam in it when i got it. cam button against an imco cover. i changed the cam and it is still a mark 4 deal, but this time a new imco cover using the water pump as a cam buttom. imco covers are very nice. i think b&b is almost identical.
