Bad gas
Results 1 to 11 of 11
Bad gas
    Nov 2008
    Orangevale CA
    Default Bad gas
    IN a fuel tank ( not ME ) , Gas was about 17 yrs old,,,, I want to hear some suggestion's on how to clean out a aluminum boat fuel tank,, I got 98% of the gas out ,, when you look inside ( took the sending unit out ) It has a heavy layer of CRAP on all the wall's and the bottom,,, If it was dry I would use the 2 handfull's of pee-gravel and shake like HELL method,, ,, SO WHAT DO YOU GUY'S DO ?????? ........ Thank's in advance ..............Eric
    Morgan Hill
    A couple gallons of denatured alcohol would be a good start...
    Maybe follow up with some toluene?
    Sounds nasty (not to mention smelly)
    GT
    Quote Originally Posted by alkyexpress View Post
    Alky whatever it takes to disolve the varnish, I use laquer thinner (let it soak) , not sure I'm crazy about the Pea gravel due to the grit (done that with coolant tanks) also alot of radiator shops will boil those tanks for a few bucks, That varnish could be hell on valve guides if it comes thru with fuel. Several year ago I lit a motor just to see if it would run in an old resto (bad fuel) and stuck almost every intake valve Tom
    Sacramento area
    Default segestion
    Put a hand full of 1/2" nuts in the tank and drive around for a week or so with it in the bed of your Pick-up. Roll the tank over to a differant side once and a while. Then rinse the crap out. One gallon of de-natured alcohol from Home Depot after the wash out is where I would start. (Same as the pea gravel deal)
    Good luck, be safe. schick
    Senior Member sturat's Avatar
    Houston TX
    I have had good luck with sea foam and nuts.
    Legalize the Constitution!
    A few gallons of E85 should eat that stuff up in short order.
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    Parts dip works GREAT.
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    okie, lake Texoma
    put some seafoam & a log chain in it & shake the crap out it, then like said leave it in the bed of your truck 7 drive around a week or so. then dump & repeat till clean.
    Log chain works better than gravel or nuts cause you can get it all outa there.
    H8-2-W8
    [email protected] first pass
    Cantard 71hallett's Avatar
    snow bank
    Diesel
    Diesel
    +1. It works great to clean old varnish and such.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    small block jet 2sangers's Avatar
    Lexington SC
    I have used a bag of ice before. Nice sharp edges, shake it back and forth, pour out the water and sludge, repeat if needed. No gravel left for the filter.
