I clicked on your picture...the picture went large...I chose properties....copied the address to the mouse. Then I selected "Ad Image" in the quick reply....a window pops up with HTTP//.
I DELETE THAT....then paste the address from the mouse in that area...and there you have it. If you don't delete the HTTP thing in the box it does not work.
The surfaces of the bearing journals are only roughed out with a ball endmill and left undersize.
In the last operations the cases will be bolted together and bored as a unit.
This is the bottom half, I am working on the top half right now.
The first operations are in a vise usually. All other setups will be done on a fixture plate using the alignment pins for location.
This part represents about $175 worth of 6061 aluminum. The scrap guy already loves this job since I only end up with 1/4 of the material I started with.
Problem with that is, I have "pop up blocker" on my internet options, or on my virus software, I tried rather unsucessfully to find where I can disable that feature.
how often do you recycle your chips? I just took a batch down today. I always look around at the other shit too. Saw 2 55 gal barrals full of these big stainless rod end looking delios. I felt pretty good about my scrap ratio after seeing that.
I've got the top case/top side done finally. Took all week of wittling on it here and there trying to get it to look right, I still have to backtrack a little when I get it finished. Working on the pictures right now.
Related Threads
Performance Boats Forum
2.1M posts
41.1K members
Since 2007
