Since we don't have a billet porn section.....
Page 1 of 10 1 2 3 4 ... LastLast
Results 1 to 14 of 129
    Thumbs up Since we don't have a billet porn section.....
    I figured you guys would apppreciate this the most.
    It is the beginnings of another billet case I am building for a custumer. Doesn't look like much right now, but it will take shape.
    It's a bummer sometimes I am unable to post shots of the parts I build.
    What do you guys think?
    Brian
    Default First Operation
    marina manor trash
    a 1/2 & 1/2 so.ca/parker,az
    Default case
    where's the photo?if you need tooling let me know.steve canales-ingersoll cutting tool 310 880-8276 really I just want ed to see the case
    Crank installed to check the fitment. Made a coupla adjustments to the toolpaths.
    Nice. One hell of an arm.
    Happy Easter!!!
    Gone
    Sparks, Nevada
    Showoff, how did you do it? I can't seem to "clean up" the properties.
    Senior Member DaveSammons's Avatar
    Carlsbad, California/ Marina Manor, Parker, Arizona
    Quote Originally Posted by vdrivenut View Post
    You still out at the River?? How'd the Poker Run go?? No more of this I hope!!
    I'll be out next weekend
    OH YEAH...THAT IS BILLET PORN AT IT'S FINEST!!
    Gone
    Sparks, Nevada
    I clicked on your picture...the picture went large...I chose properties....copied the address to the mouse. Then I selected "Ad Image" in the quick reply....a window pops up with HTTP//.
    I DELETE THAT....then paste the address from the mouse in that area...and there you have it. If you don't delete the HTTP thing in the box it does not work.
    The surfaces of the bearing journals are only roughed out with a ball endmill and left undersize.
    In the last operations the cases will be bolted together and bored as a unit.
    This is the bottom half, I am working on the top half right now.
    The first operations are in a vise usually. All other setups will be done on a fixture plate using the alignment pins for location.
    This part represents about $175 worth of 6061 aluminum. The scrap guy already loves this job since I only end up with 1/4 of the material I started with.
    Brian
  13. #12
    Unfortunately, the pics are now gone because WSUWRHR edited his posts and deleted the original attachments.
    Its easier to just upload the pics to the "You Shot It" gallery and then treat the pics like any other image you want to post.
  14. #13
    Crystal clear, will do next time. I just stole your properties and reposted.
  15. #14
    Default Tried that
    Problem with that is, I have "pop up blocker" on my internet options, or on my virus software, I tried rather unsucessfully to find where I can disable that feature.
