MSD Digital 7 or stick with the Mag
Results 1 to 14 of 14
    Menifee
    Default MSD Digital 7 or stick with the Mag
    What makes more power an MSD with a digital 7 or a mag setup. I am currently running the mag but was offered to try out the MSD digital 7.
    What are the pros and cons? Has anyone ever dynod the two?
    Thanks.
    DJD
    DJD is offline
    6TH STREET MAFIA PRES. DJD's Avatar
    Closer to the river than you!
    Thanks.
    On a gas carburated deal i would use the the digital 7. im going to try a digital 7 for the first time on a blown injected alky deal in a few days but,i am leary of it cause im afraid that when it hits the limiter it will blow the flame out and likely not relight untill after its shut off and has a chance to dry out. I would imagine that on a deal like your it will be a valve spring saver for sure.
    You should get a lot of opinions on this one. A few years back we dynoed a MSD 7 against a Vertex standard mag. In a 850 HP BBC, didn't make squat for difference...
    We used MSD's in our race car. The MSD gives you lot's of options in terms of timing curves, start retard, rev limiters and is generally easier to use on board data acquistion (if that's a consideration). Certainly that's a large part why MSD's are in every NHRA Pro Stock engine.
    We just got off the dyno with our new engine and wanted to test our mag against the dyno shop's MSD. Unfortunately, the mag caused to much interferance to get decent readings. The dyno guy's opinion is the same as what we found out in our earlier testing, very little difference in HP between the two for an application like ours. We had the choice, will start the year with a mag for its simplicity.
    B1 Racing cs19's Avatar
    digital 7 has all kinds of cool features including data aq. and individual cylinder timing but if you arent good on a lap top there is no reason to get a digital 7.msd software is a pain in the ass.
    B1Racing.net
    Newton Ks.
    IMO you won't get any worthwhile difference.
    If the extrta "cool" abilities of the MSD box are OF USE to you, then get it and use them. Looking for MORE POWER from an ignitiobn change, to get any, the old one needs to be malfunctioning somehow.
    H.L. Mencken
    lawnmower repair man
    Thanks.
    STICK WITH THE MAGNET
    Big Boys Toys Murray PE 857's Avatar
    My drag hydro has a 604 BBC w/ 1471 supercharger and alcohol inj. I bought a MSD 10 box and coil and it works great. 1500hp/1500lb.ft. on dyno. Crank trigger set up.
    Menifee
    Thanks for all the replies guys. The Mag has worked flawless and for what I am using it for it seems just perfect. I was offered the use of the MSD setup to see if there would be any changes or advantages other than the variable timing adjustmenst and just concentrated on the power diff between the two types of ignitions. From what you guys have told me I'm not even going to bother.
    I'll stick with the magnet..........................
    And Chris, I don't even know how to open a laptop let alone program one with software and all that stuff...
    JGB
    JGB is offline
    Senior Member JGB's Avatar
    YUMA
    In my experince MSD keeps the spark plugs cleaner and is easier to start. But I have ran the fastest with a mag. Not saying that had anything to do with it though. Great question would like to hear more.
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    Quote Originally Posted by Murray PE 857 View Post
    Talk about overkill!
    Adam
    Hallett 210
    Shiloh, IL
    I'm with Lowrider. If you can use all of the advanced functionality of the Digital 7, then go with it. But, don't go with it just because you think it'll make more power by wiring it up. By the way, you never mentioned what kind of mag you're running.
    Adam
    Hallett 210
    DAYAMMM, all that to run PE?? That thing should run in the 6's... Overkill indeed
    [email protected]
    Ohio
    I seen an article in Hot Rod years ago that compaired all the MSD boxes. These were before the digitals. They all were within a couple of HP, with the 6AL making the most.
    doesn't look overkilled to me........
