Chevy Crate Motor
Results 1 to 14 of 27
Chevy Crate Motor
    Clovis
    Default Chevy Crate Motor
    Was wondering if someone with real know-how could explain to me why a chevy big block crate motor will not work in a marine application. The 572 720hp motor looks killer but engine builders in my area say it wont work and will blow up. Same with evey other crate motor, 502, 454, ect. Any info would help.
    Thansks
    Lurker
    NC
    They are nice pieces for a reasonable price.
    May be a tad tight clearance wise for marine use as shipped but many are using them with good success.
    Is that your's Outlaw??
    If so you should be a good source of info!
    Everyone I know that's used one of the GM crate motors has been happy with it. I haven't done one in years, but the last couple I did, I took apart and checked everything out. Most issues were minor...
    With a lot of engine builders, whatever you have is junk and should be throw away. Whatever anyone else built is NFG and you will be lucky if it even runs. Anything your last engine builder told is wrong (this is can be true even if it's the same guy and some time has passed).
    All engines are compromises in some way... Ask lot's of questions, use a bit of common sense and make your mind up what's best for you...Good luck
    no not mine Its off hi tech's web site
    I frequent a few other website forums where there's a little higher level of racing participation, and I've heard plenty of horror stories about these and other crate engines. Mostly due to poor clearances/oil pressure issues, and power that's no where near advertized. My advice is, when ever you buy a crate engine, at least tear it apart and inspect it closely. All it will cost you is gaskets, and some time, but it may save you lots more in the long run. My guess on the marine issues is they're not built for marine use, so they're going to have all kinds of disclaimers.
    Just my .02 FWIW
    Member JAY4SPEED's Avatar
    GM crate engines are not warrantied for marine use unless the specific model crate engine is designated for marine use by GM. So, you could drop 12K in a 572 and your on your own as far as warranty goes.
    Jay
    "You just can't fix stupid!"
    Atlantic Beach, FL
    Plenty of out of the box motors have gone in ski boats over the years. It would be a matter of application, IMHO. If you're going to run around, ski, a few blasts, probably fine. If you think you're gonna wring it out and beat the crap out of it, have your builder tear it apart and clean it up for a couple grand.
    No free lunches...
    ever single gm crate engine i've worked on and dyno'd was underrated by gm by about 20-30hp....
    The 502 dyno sheet that I posted on the other thread started life as a GM short block. I had ESI pull it a part and blue print it. As Warp stated the clearances are a bit tight for marine use. I know people have just droped them in a boat, but my friend wanted an engine that would last for year's with out any issue's. The blue-printing was money well spent.
    As Scott said ,I would have one torn down and checked out. I do have a friend that blew up their crate engine (502) 3 times last year. Chevy replaced it the first time, it blew again then Chevy tried to fix it for them twice blew each time. I told them after the first time to take it to an engine shop and blue print the damn thing. Some people have more money than brain's.
    Sleeper CP
    Newton Ks.
    Duane says that is one great jet boat motor, out of the box.
    Just has lousy results out of the Demon carbs on them. I think he has a whole closet full of them available CHEEP.
    H.L. Mencken
    East Side
    Quote Originally Posted by sangercat View Post
    Thansks
    The cause for concern is with the clearances because you are using cold lake water to cool the motor. I don't know the exact specs of this crate motor but a few other things to look at are the cam specs, brass freeze plugs and fittings, and a larger oil pan.
    just what part # do they put on the 572? How cheap??? I need one for my
    68 El Camino
    Newton Ks.
    68 El Camino
    Ask Duane http://hi-techperformance.com/1-417-856-8616
    H.L. Mencken
