Cam duration
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 46
Cam duration
    Cantard 71hallett's Avatar
    snow bank
    Default Cam duration
    How much duration can I run in a bbc before it starts drinking water or can that happen?
    Senior Member crf311's Avatar
    Meraux, LA
    With logs for exhaust, I was told to stay below 230 duration. Check with your engine builder
    Quote Originally Posted by crf311 View Post
    I agree here
    G H E T T O F O E L I F E
    I thought having a narrow lobe center/seperation had some(bad) effect also? Like 108*. I guess both add to valve overlap?
    Lurker
    NC
    It all depends on the exhaust event and how late the exhaust valve closes. You can go up in duration a bit but need to open the lobe seperation accordingly so the exhaust still closes early.
    Straub could explain this allot better than I can, and can probably tell you exactly the duration for a given lobe seperation/installation point.
    Swollen Member SinisterGrin's Avatar
    It greatly depends on what kind of exhaust you are running, i.e. stock manifolds, headers (what brand or style), etc. All play determining factors, it depends where your exhaust gases and water meet. Some exhausts you will see reversion as low as 230 @ .50l like stated above and then on some others you can push it alot higher. Lets get some more info on the application and exhaust.
    Default cam duration
    I have a stupid question. I thought exhaust logs like a Glenwood or Nicson wouldn't drink water as bad since they are jacketed, and water doesn't enter the exhaust side till it reaches the riser. I have a 427 ford with 258 duration at .50 ground on a 110. I'v been running this combination for 18 years with no problems. I'm working on a simular project with through transom exhaust but a BBC, am I going to have problems with this that I didn't with the FORD. Thanks!
    Better idea
    Run dry headers or Zoomies Like Me!!!!!
    snow bank
    Better idea
    You know it!! Going to run them dry and get to the point.
    Kilowatt , I believe the answer to your question is that it can suck it right from the lake/ or from the water dumps into the snails.
    Newton Ks.
    Quote Originally Posted by MR. KILOWATT View Post
    No, you should not have problems with that either.
    Logs are even "drier" to the exhaust stream than my jacketed headers are IMO. To pull water backwards in a log you have to pull it VERTICALLY up a 2 to 3 inch barier, then pull it from 5 inches to over a foot (depending on which cylinder).
    My headers would have to pull backwards at least 4 to 6 inches up a 45* incline, to pull something into the tube, then go down over 18" to a port.
    I am running jacketed headers, a 240+* duration cam, in a Chevy, 4 years now, and have NO issues.
    Same cam ran 2 years with logs, 2 years with the headers now, this year is year 5.
    The bad boy is the injected header which puts a water spray just a couple inches away from the exhaust valve. At moderate to high RPM, the gas flow blows the water away. At idle, this does not happen and as the piston heads down it CAN "suck" pretty hard for a fraction of a seccond untill teh valve closes. This is one of the reasons why you have to cut water to injected headers at idle, and also why you run significantly LESS water to cool them.
    H.L. Mencken
    I could be wrong. It just seems like it could crawl up over a snail as eaisly up a header tube. I dunno. I don't think all reversion cones from the injection lines. ??
    Newton Ks.
    I agree MOFO, but it would (IMO) take more overlap pull to get reversion troubles from a log or jacketed header than from an injected header with excess water fklow (at idle).
    H.L. Mencken
    I just went through all this while selecting a cam for an engine that is being built for my inboard ski boat which has an exhaust below the waterline. Basically you do not want to have any overlap on the cam that will allow the intake and exhaust valves to be open at the same time at the beginning of the intake stroke because that will cause a vacuum which may suck up water. If you know the specs on your cam, the site below should prove to be helpful, it has two simple formulas that can be used to ensure that there is not any overlap using 0.05 duration numbers.
    http://www.empirenet.com/pkelley2/Overlap.html
    Hope this helps.....
