15 or 30lbs?
Results 1 to 7 of 7
15 or 30lbs?
    Default 15 or 30lbs?
    Hi Guys
    I found performance boats mag in with my shipment from CPPerformance and so here I am. :-)
    So I wanna take off my 30lb flywheels on my bbc's and fit the 15lb ones.
    Starters are on there way out any way so I can overcome that issue and justify the cost too!
    Any big reasons why I shouldnt do this?
    Steve
    Newton Ks.
    Why not just go with flexplates, or are you still double-clutching it?
    No reason not to change it other than possible driveline differences you may get into.
    I can't think of 1 really good reason to run a flywheel unless you actually DO install a clutch assy in the boat, and why you would do THAT is beyond me.
    H.L. Mencken
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    I run a flywhel and torque coupler
    My thoughts on the heavier flywheel in pleasure boat ! when you launch off the rollers you will not build rpm as quick and when you re enter you still have centrifucal force on your side . I believe this combo will help longivity of parts along with harmonics ! JUST MY THOUGHTS - and as you may or maynot have noticed I am nobody
    [/SIGPIC]
    Senior Member Hallett's Avatar
    Lakehavasu az
    Some people say that a flywheels help to absorb harmonics.
    Olympia, Washington
    Not to mention a flexplate was designed to be bolted to a torque converter to stiffen it during cranking. Some people never have a prob. some get the horrible grind!
    cfm
    cfm is offline
    I think a good question is "What appilcation - jet, v drive, I/O and what engine size are we talking about ?"
    If I/O, what kind of drive ?
    Nechako
    Exclamation don't do it
    agree with lucky and hallett I run a big heavy flywheel and the large ATI dampner , don't think it matters what drive your runnin , boat engines are under heavy load and when held at a constant rpm or are unloaded they will develop damaging haromics if you don,t run the heavy stuff . your starter will last better too, especially with a big hi-compression engine .
