push rods
Results 1 to 14 of 35
push rods
    Arrow push rods
    I plan on installing a set of
    Iron Eagle 308 heads on a 1999 502 cid 415 MPI engine, allso a set of comp. cam. roller rocker Arms. I would like to know if the push rods have to be changed.
    Newton Ks.
    This may or may not be a lot of help Ken, but last spring I changed from stamped rockers to Comp Hy-Tech stainless steel roller rockers on my Mk-IV Chevy, and didn't have to change anything but the polylocks to the Comp locknuts (oh, and the studs to the longer (1.90") ARP studs). If the Iron Eagle heads won't force a pushrod change, I don't believe the rockers will. The heads are the risk point IMO.
    Changing rockers sbhouldn't require a pushrod cahnge, but changing heads, especially to an aftermarket head will most likely require different pushrods, if you want the geometry to be correct. If it's not, you may cost yourself a good percentage of the HP gain you were looking for (and paid for) by the head swap. It's easy to check proper geometry, so why not be sure?
    Now, go ahead and someone ask...what's right way to check PR geometry?
    That's a whole new thread.
    Arrow
    O K what is the right way to get the proper push rod geometry.
    Gone
    Sparks, Nevada
    Thanks Bob...that oughta keep him busy for a while.
    SoCal
    Jim miller got it
    Olympia, Washington
    Well after reading it all 2 or three times it all makes sense, kinda makes your head swim for a while though.
    Gone
    Sparks, Nevada
    http://unix-scripts.com/hb/uploads/Lun1.JPG
    http://unix-scripts.com/hb/uploads/Lun2.JPG
    This is old and hard to find. I suggest you save it. Was written by Miller years ago.
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    Fiat, Any chance you could repost that Lunati material as a pdf file. I'd like archive it for future use. I could'nt get it to format into a readable doc.
    Gone
    Sparks, Nevada
    Nope cause I am not good enough. LOL. Maybe somebody is.
    But I did notice a couple things. In explorer....when the mouse is moved over the doc a magnify glass appears and you can blow it up.
    Also in Explorer....the option "tools" and select full screen helps.
    I was lucky to find it. I sent that to "Shaun" and he happened to keep that on his site. That is out of an old Lunati Catalog I have. I still use this method.
    Quote Originally Posted by Speed of Heat View Post
    I left clicked on it like I wanted to print it and then a prompt came on the screen that said " enlarge to regular size".
    Sleeper CP
    Big Inch Ford Lover
    Nobody
    Big River, Ca
    It's a picture just click on it to enlarge it then right click and save it!..
    Quote Originally Posted by GoFastRacer View Post
    I've tried everythig I know...can't even save it.
