Oil pump question
Results 1 to 9 of 9
Oil pump question
    Senior Member repoman's Avatar
    norco
    Default Oil pump question
    does the pickup need to be welded to the pump or can it be brazed?
    You can do either. I would Tig Weld it. The brazing process gets the pump real hot. I would be afraid to warp it. That is just my opinion. Maybe someone who knows what they are talking about will say something else.
    P.S. Where do I call to get flowers delivered. I would like to see their garden as well.
    MPR FAB southwind011's Avatar
    riverside ca
    i would tig weld it
    norco
    thanks guys tig welding it is
    The Right Coast/SE-PA
    Nice vases
    Mar 2010
    I'm in the same stage of doing this also, but I'm also curious as how to measure and confirm the pickup to pan depth and what depth should it be ?
    Mar 2010
    found out what i was looking for, it should be fine anywhere between 1/4 - 1/2 inch from pickup to bottom of pan. The manufacturer should be able to provide the specific # for a particular application. Mine was 3/8 of an inch. Also the torque spec for a bbc oil pump bolt is 65 ft/ lb. Hope that helps anyone out there.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by repoman View Post
    Dont run a bead all the way around which will really heat the pump; just tack it in a couple of spots, that's all you need.
    High Flow Dynamics
