valvespring installed height for 302 ford procharged
Results 1 to 6 of 6
    Default valvespring installed height for 302 ford procharged
    Huch more seat pressure should a supercharged marine engine run than an auto engine? And what else should i know about setting up a valvetrain in a marine motor?
    Last edited by onefastt; 07-06-2010 at 02:09 PM. Reason: first question made no sense.
    You do know what the required spring pressure is for the cam your running is.....right? Lets start there.
    130 lbs seat pressure 350 open
    OK. Take the diameter of the intake, find the sq inches, Dia X Dia X .7854. Multiply that number by the PSI boost=increase in spring pressure required. Minimum.
    Diameter of the intake port or valve? And should i leave the exhaust set up at 130 or do the same
    Gone
    Sparks, Nevada
    valve.
    Carry on.
