What causes Surging?
Results 1 to 14 of 42
    Denton, TX
    Default What causes Surging?
    I put my motor back together and it surges. I started to think about it and it's always done this since I got the boat. I checked all the usual things vacuum leak around the gaskets etc. sprayed starter fluid around and didn’t get anything. I have had two different sets of carbs on there surges with both. I am running a little 177 blower but I don’t think its big enough to create blower surge. The surge is anywhere from 200-400 RPM and it doesn’t happen quickly it happens slowly. It almost sounds like its going to die but then the rpms pick back up and it idles fine.
    What can cause this?
    Specs: SBC, 30/30 cam, lash 24/26, 177 blower set at 7lbs. Duel 400 carbs. Eletronic Ign.
    Don’t know if you need any more info.
    Morgan Hill
    Without seeing, touching smelling and tasting
    It sounds like a hunting distributor advance....Maybe watch the timing while it surges...
    GT
    Denton, TX
    Oh yea it’s done it on two different dizzys. Is this necessarily a bad thing?
    273.36 Miles from Havasu
    Blower surge is fat (and happy) at idle.
    Perhaps I'm gay...
    Quote Originally Posted by Havasu Hangin' View Post
    Morgan Hill
    Blower surge is vacuum scavenging, not necessarily fat, more of a fat/lean alternation.....Can be tuned out on most, if not all if desired. It is typically how the carburetors are "referenced", if referencing atmospheric pressure on an over driven deal, they can be fun to tune ....(note the sarcasm)
    I don't think your deal is blower surge.....What type of exhaust are you running?
    GT
    What is your Dist set-up? Does it have a vacuum advance? If it does burn it. I am leaning toward timing as well.
    Denton, TX
    It’s a Mallory Comp 9K no vac. advance, set up at 6 initial and 30 total.
    Exhaust is OT bassetts with the bigger primaries.
    Morgan Hill
    Do you have a clue of the camshaft and where it is degreed in (advanced vs. retarded)?
    I would think if it does it with two different carb setups and two ignition systems it would be something done when the motor was built.
    How well does it run up top? What do you have the plugs gapped at? With boost, or a high CR, sometimes you need to narrow the gap of the plugs because it is harder for air to ionize (spark) at a higher pressure...Do you know how much boost there is present at idle?
    I figure if I throw enough darts I'll eventually hit a balloon and win a kazoo or something...
    GT
    Denton, TX
    Thats the way most things are done just F with it until you brerak it further or fix it.
    Plugs are gaped at .35 (NKG, 6 on the heat range) No boost at idle (vacuum gauge) holds about 10-12 HG at idle. As far as the cam, no clue.
    Team CJ460 Just Electric's Avatar
    granada hills
    do the primary butterflies on your carbs have a small hole in them to lean it out at idle?
    Orlando.FL
    Sounds like a lean carb, adjust out, maybe air bleeds plugged run some wd 40 thru them.
    cfm
    cfm is offline
    Quote Originally Posted by Btnhtillidie View Post
    6° Initial is pretty low.
    Set base timing to where it idles the best and then change your dist advance so that it ends up providing what you want for total.
    Then, go back and re-tune your idle mixture screws. Then carb mods if need be.
