Big Block Stroked Mopar (Cam Help)
Results 1 to 14 of 14
    Junior Member istandalone's Avatar
    May 2010
    Lansing, MI
    Default Big Block Stroked Mopar (Cam Help)
    400 block, bored to 4.382
    440 Source 400-451 Stroker Kit
    Iron race heads Big time Ported!!!
    2.14 1.81 manley race valves, 10 deg titanium retainers
    Harland sharp rockers
    Windage tray
    ARP main studs
    ARP head studs
    CAT fluidampr copy.
    Complete ICE ignition Setup
    2x625CFM mech Holleys on a weiand tunnelram
    If you need any more info please ask Cams I have are
    Hyd comp cams .507/.510 240/246 duration
    Herbert custom grind - solid roller .606 lift, 246 duration on a 110 LC
    Boats Name "Glory Hull" Same boat my brother died in 3 years ago 1974 Sidewinder (took awhile to find one), undergoing FULL Deck off restoration back to his original Specs...With a Few Upgrades...
    San Francisco Bay Area
    Cool
    I won't pick your combination apart since we all have different approaches (most of which are perfectly fine), but I must speak up about the CAT fluid damper for two reasons: 1) CAT, and, 2) fluid damper.
    1) A lot of CAT parts, specifically the ones with moving parts or which require some sort of assembly at the factory (such as a balancer or waterpump or rocker arms) don't seem to endure high performance applications. Today, I think that their solid parts (main caps, connecting rods, etc) are fine in many applications provided that they are fully measured and inspected prior to use.
    2) A lot of aftermarket stroker kit companies will not warrant their broken crakshaft once they learn that you used a fluid damper. The warranty is automatically VOID. Here's is a quote from the SCAT website, for example:
    DAMPERS WITH MOVING INERTIA WEIGHTS
    A. Fluid, balls, springs, inertia rings with rubber O-Rings, etc. Can
    you balance a wheel on your race car if the tires are flat???? How
    can your rotating assembly be balanced if to quote one
    manufacturer, “These units (Dampers) should not be on the crank
    for balancing as the inertia weight may not be centered until the
    engine starts.” NEWS FLASH!!!! Centrifugal force will always take
    the inertia weight off center no matter what RPM. Your assembly
    is never balanced. TELL TALE SIGN!!!! Metal transferred on nose
    outside diameter and damper internal diameter . . . A fatigue crack
    starts. SNAP!!!! The crank breaks
    The above quote is not my personal opinion but is from the SCAT website, and they will point to it right before they show you the door.
    If I were you I'd ditch the damper. That is my opinion.
    LO
    High Flow Dynamics
    May 2010
    Why not run the roller if you have it?
    Quote Originally Posted by LakesOnly View Post
    LO
    I'm sure you're right on Scat not warrentying a broken crankshaft, but that's more indicative of MOST Hi-Po mfg's assumption that every part they sell is perfect and if it breaks, it's because the customer is a dumbass (just went through this with a prop shaft ). I think it's funny that Scat quotes another mfg in their quote!! Might as well write something and quote yourself. Don't get me wrong, I like some of Scat's parts and I rank them above a bunch of the more common offshore mfgs. However, the engineering in the above quote is simply wrong.
    Metal transfer between the hub ID and crank snout OD is because the hub isn't tight enough. A damper has to fit TIGHT in order to dampen crankshaft torsional vibration (sometimes referred to as "harmonics"). This looseness won't lead to a fatique crack. If the balancer was seriously out of balance, then you could potentially bust the end off, but that's a seperate issue.
    Also, pretty much EVERYTHING they said about balancing is wrong except balancing components seperately. Finally, there are tens of thousands of fluid dampers in everything from heavy duty industrial applications to weekend bracket racers.... Used properly, a decent quality fluid damper is fine.
    Cool
    That's all fine and dandy.
    Also, the parts will not be warranted with the use of the fluid damper, which is one of my points. The CAT components that are made of muiltiple pieces are still failing regularly out in the field, which is my other point.
    LO
    High Flow Dynamics
    Senior Member 1fastmopar's Avatar
    Whats the C.R.?
    May 2010
    Lansing, MI
    Quote Originally Posted by 1fastmopar View Post
    Whats the C.R.?
    Will be about 10.2:1
    Quote Originally Posted by istandalone View Post
    The .606 cam is the one I would run, whats the dur @ .050?the only thing I dont like about the second cam is the LSA Its a little tight a 112 would be much better!
    May 2010
    Lansing, MI
    I really droped the bomb on the second one sorry, here are the specs.
    Full Roller
    RPM Range 4000-7000
    Valve Timing 0.02
    Lobe Center Angle 108
    intake centerline 108
    Valve Lash intake 0.028 Exhaust 0.03
    Duration intake 306 Exhaust 306
    Duration @ .050 intake 275 Exhaust 275
    Valve Lift intake 0.625 Exhaust .625
    Lobe Life intake 0.416 Exhaust .416
    Valve timing @ 0.02" Lift
    Intake 45 BTDC (OPEN) 81 (CLOSE)
    Exhaust 81 BBDC (OPEN) 45 ATDC (CLOSE)
    Tri-Cities, TN
    As someone who has experienced a CAT fluid damper come apart on the dyno during the first full pull, I would not put one on a model engine. Go Romac for an affordable alternative that is a quality piece.
    Big time ported heads should have flow numbers. Need the flow numbers along with the rest of the info you have posted and a target rpm range to properly cam an engine.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Is the Cat a copy of the older Fluid damper ?
    My Fluidamper ran on the 512" for two yrs and then on the 565" for several yrs. Spun the thing 6,600- 6,800 for yrs.
    S CP
    Any body ever hear of big time ported heads flowing worse CFM/area, than stockers with a bowl clean up. Sounds alot like a case of B.I.B./B.B.I.B. Bigger Is Better/But Biggest Is Best
    I happen to mention to Tom Lieb (Scat) that I was running a ATI, inertia ring, with o-rings. He shrugged and said "there are worse things you could do." Then I mentioned it was blown, and the boat is driven off the snout. He smiled, and said, "see, there are worse that you could do."
    I have been running a fluid dampner on a sea doo motor that has been abused for the last 10 years and never a problem. Makes a drastic difference in reducing vibration that is felt from the motor. Seeing that they are causing problems on v8 motors, I will probably never try one.
