blown alcohol wrist pins
Results 1 to 14 of 19
    Default blown alcohol wrist pins
    I have a blown alky bbc with 1.094 wrist pins but its coming time to put rods and pistons in it im thinking about going with the .990 wrist pin set up its a easier piston to get and a good bit cheaper how much power will the .990 wrist pin take. A custom set of pistons for the 1.094 wrist pin start at 1200.00
    Peoria, AZ
    Call Venolia. Is that for a set of twelve?
    Paul
    Quote Originally Posted by matt wheeler View Post
    $1200 is about right for a custom set of 8. Our last set was $1600 for 10, coated & gas ported for a BA application. Not sure a .990 pin would be much cheaper unless you found a set of "off the shelf" pistons. I never found any that would work. A broken wrist pin is one of the worst engine failures you can have, so I wouldn't go to light on them...
    Nov 2008
    Orangevale CA
    X2 on the THICK pins , I am using .990 pins but they are the ferria .250 wall tapered pin's ,,,, have had good luck with them ,,,,,,,......E
    i'm back!! 1QuickCP's Avatar
    Montana
    I would not run a .990 pin in a blown alcohol deal,
    now if ur just runing like 25 psi or something you probably be ok with .990 .250 wall. But really if ur building a serious BA motor big pins r the way to go.
    Default wrist pins
    Well i will probably just go back with what i have then i havent had any trouble with this set up at all, im running venolia pistons with fowler rods tall deck bbc with a 3.76 stroke, 30 over 427 and a 6.535 rod it runs great. Times a tough right now hard to fork out 2500 right now but i can just see having to do it twice if i dont go back with what i know works. thanks alot guys just need a little talking into something every now and then
    Gone
    Sparks, Nevada
    I always used C&A 185 gram taper walls. I always ran a shelf TRW or Manley Pro dome piston. Never a problem.
    Then I happened to build a "backup" motor. Had a new set of Trw pistons....but money was tight....I'd just run the TRW pins for "now"......later I was gonna go back in and do a set of C&A taper walls.
    I never got the later.
    She made one pass. One pin let go in the lights. All we found were "chrome looking shavings."
    But I didn't have to worry bout a backup motor after that cuz there was not much saveable.
    LOL
    A connecting rod, tied down only by the big end, can be a very ugly thing. Just never seems to have a nice ending.
    Default wrist pin
    Im also running the buttons i dont really see the need in those they are cool for a quick pistons changer if you melt one but thats also damn expensive to have done im going to go back with the spirolocs
    Default pistons
    Also guys what do you guys think about 12to1 compression i have always heard thats a good blown alcohol motor and it has been but im thinking about going with a little less compression and alittle more boost i wont get over 25psi to run 8s in my hondo runner bottom sorry for all the questions i just know you guys know alot more about it than i do i have been building motors for awhile now but i dont know as much as some of you but i think im doing alright for 23 year old guy i havent throwen the rods out of my blower motor yet but i know its coming
    Default blower
    I have also upgraded my blower some went from a 871 mooneyham to a 1471 mooneyham im running a summer brother front drive set up this stuff here is all new to me but looks like its going to work out well
    waterloo
    Big pins are not necessary in anything but a real competetive BA deal. (30+ boost)
    .990's are run day in and day out in pro mod engines.
    12.1 to 1 is a little high. Easy enough to slow down the blower, though. You better have port nozzles to tune cylinders.
    Go with a shelf piston if you can. They are cheaper, and faster to replace if one is damaged. I'd sacrifice some compression for a shelf piston if I had to (especially with a 14-71 on a 427) (I actually did on a 492. I only have 10.5 on the pe boat. I'd prefer 11.5 to 11.7 but shelf piston thing again)
    Good luck.
    Wags
    Default boat
    Hey wags your old boat went to walter dulin right, i hope he didnt screw you around to bad he lives right by me he is a hated guy around here
