blower pistons needed
Results 1 to 9 of 9
    WHITTIER CA
    Default blower pistons needed
    i need to get a set of pistons for motor not opposed to getting new ones but if i have to pay to have them made i would like an input on who to place my order with. its a gen 4 block with a 4.250 stroke 4.320 bore and a 6.3850 rod a 111cc head and im trying to get it as close to 8:1 as possible........... i apprecite all of the help in advance
    This is about as close as your going to get off the shelf with that chamber. 11.5 cc dish. If you go custom, Arias, Venolia, JE, CP, take your choice. Or you run a flat top and a thick ass gasket.
    http://www.summitracing.com/parts/UE...n/?prefilter=1
    http://www.kb-silvolite.com/icon/ico...tails&P_id=561
    WHITTIER CA
    I havent head good expierence with kb pistons, the ones that i ran were hypereutectic though, would you run them in your boat? My application is a recreational flatbottom. Not trying to break the sound barrier just run trip digits and stay together
    Quote Originally Posted by SCSRIVERRAT View Post
    The new Icon forged pistons from KB don't look too bad, but I think it might be worth the extra money to step up to a better piston with the blown application.
    I have run them. Don't know what your issuses were with the hypers, the vast majority of the time they are set up wrong by the machine shops. Too tight on the bore(for a boat) and then too tight on the rings for a hyper. These are forged. and they are a different animal. I beat the hell out of one these. I am still amazed it stay in one piece.
    WHITTIER CA
    What would the proper clearance be on the piston
    Yeah I totally agree. So would a Sonny Bryant Crank, Carrillo or Oliver rods, Dart or Merlin race block. Maybe even a Donovan or Brodix alumn block
    Senior Member repoman's Avatar
    norco
    I agree. When I bought my boat it was making 12 lbs ob boost under the chiller running av gas. when it was time to freshin it up I was shocked to find hypers in it especially when they were 10.5 to one. they looked fine considering I ran the s%$T out of it.
    I've had good luck with hypereutectic pistons in a asphalt drag racing motor. Should be fine in a lake flatty. I wouldn't hesitate to run them again if they had an off the shelf part that no one else did... That's the reason I chose them on the one motor I used them in. That said, if I had a choice, I'd go with a decent forged piston even if it cost a few bux more...
    Good luck.
