Surge at WOT
Results 1 to 14 of 14
Surge at WOT
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Surge at WOT
    Since getting the new motor in my boat i've had a surge when mashing the gas from a idle or slow cruise. Before the boat wanted to jump out of the water so i figured it was caused by the pump being loaded/unloaded but i no longer think that. When cruising or launching and then getting off the throttle it doesnt do it. It's only when i mash and stay on the gas. I beleive it was RCB19 who recommended that i get a special floats that where thinger at the rear of the bowl so that when the fuel came up the side it wouldnt shut off the needle. Sombody else recommended getting carb plates with angle to them. Wondering what some of you guys may think it happening.
    http://unix-scripts.com/hb/uploads/2010-07-10-1.avi
    http://unix-scripts.com/hb/uploads/2010-07-10-2.avi
    http://unix-scripts.com/hb/uploads/2010-07-10-3.avi
    http://unix-scripts.com/hb/uploads/2010-07-10-4.avi
    http://unix-scripts.com/hb/uploads/2010-07-10-5.avi
    http://unix-scripts.com/hb/uploads/2010-07-10-6.avi
    Shaun, if the surge comes alittle while after you mash it, I doubt its the floats. That would show up almost immediately after you punched it. What regulator are you running. And what pump.
    Morgan Hill
    Shaun, I agree with gn7, it sure sounds like a starvation issue......
    Almost like you are aerating the fuel pump (would mimic a vapor lock)...
    GT
    San Clemente, Ca
    Mallory Regulator, Mallory 110 GPH Marine pump. Pressure stays at 6-7 PSI while the surge is happening.
    Morgan Hill
    You can still have 7 PSI and be aerating the fuel, so may be a good idea to check for potential leaks at joints to be sure.
    As weird as this sounds, maybe extended jets in the rear bowl?
    If you back out ever so slightly, does it go away? I would love to see a spark plug or two after a hard surging run and a hard shutdown, that may tell a story....BTW, do you have a rev limiter? what pill? I have seen these do some moronic magic .....
    GT
    San Clemente, Ca
    Well, the fuel rail and regulator are mounted to the manifold. Could vibration be aerating it that bad? And if so, why only when from a idle? I can stab the gas at 3K rpm and get no surge. I have never tired to back off the throttle a tiny bit during the surge. I do have a rev limiter (6AL box) with a 6400 RPM pill. The surge is happening around 5000 RPM.
    Rear bowl? These are mounted sideways
    Morgan Hill
    Then "front jets" LOL could be starving the forward jets from the fuel level and sucking air....
    A good experiment would be to raise the floats 1 turn....That is if it does not flood...
    Not an expert, just play one on the forums....
    GT
    cfm
    cfm is offline
    You can still have 7 PSI and be aerating the fuel, .
    I had a dyno fuel flow meter that did that to me. Proof was me looking thru the glass sight bowls during many full throttle runs while the engine shaked/bucked going over 16:1 A/F ratio and me trying to cover my privates in case the engine would kabloom.
    Went thru this pulling/changing fuel system components one by one. Everything returned to normal when the meter was removed. Meter was on the pressure side.
    Fact, not theory.
    Morgan Hill
    Fact, not theory.
    The number one reason I try to get at least a foot of fuel line after the regulator, unless it is a bypassing dealio..You can get "flash gas" to the carbs....
    GT
    What rail? Are you running one of those Mallory regulator logs. Does it surge until you let off or does it go away after time. When you punch it from a cruise, it never happens, no matter how long you stay in it. Maybe raise the fuel a tiny bit. All the bowls. If they have glasses, get it above half way. We are running the circle track floats with the carbs turned sideways. With the thin tapered side to the back. They helped.
    San Clemente, Ca
    Bob, it's one of those from rex, nothing special. Suppose i should call it a fuel block and not a rail I'm going to check my float levels the next time i'm on the water. My old motor i had a issue at WOT where i was draining the rear bowls but it wouldnt happen until a few seconds into WOT. Also it felt totally different it wasnt a surge but was raspy sounding! One thing i noticed this trip out was that it also was doing it if i made a hard turn after i made a pass. I wonder if my foat levels are set too low.
    San Clemente, Ca
    Bob, also the surge eventually stops if i stay on the throttle.
    Morgan Hill
    Raise the float levels and move the regulator and you should be GTG..
    BTW, Dat purdy...
    GT
    BTW, Dat purdy...
    Yep! That was a worn out POS on the side of Dads garage. Shaun built two motors for that thing, over the internet. I can say one thing. He follows instructions well.
    Shaun, get over here and pick up my monitor. That last post knocked on the floor!
