Anyone Running Olds 215s?
Results 1 to 7 of 7
    Jul 2010
    Default Anyone Running Olds 215s?
    Hi, everybody!
    My name's Matt, and I am about to begin a custom project. I will not mention what type of hull I plan on running, as I am sure people will look at me like I have seven heads, but the plan is to use a small 8 in a 14-15' craft. The engine I most desire to use as of now would be the Oldsmobile 215ci aluminum V8, made famous by the Y-Body GMs of 1961-1963. I plan to use an Olds mill because the Buick/Rover variant is a nailhead, and can be tough to find parts for, even in comparison to the Oldsmobile engine. Also, I have two friends who both have project cars which feature the plucky little alloy V8, and we could trade parts around.
    The question is this:
    Has anyone on PBF used an Olds 215 in a non-stock application, and what kind of luck have they had with it? I am also curious as to what type of hull it was in , the size of the hull, and the type/brand driveline used behind it. Details on the engine build are also more than welcome.
    Thank you,
    Cobrawannabe
    Nov 2008
    Orangevale CA
    no info on the 215 , but welcome to the boards ...............Eric
    Nov 2008
    Fuquay-Varina, NC
    Sounds cool. What about using the Buick/Rover variant, but one of the newer ones? I've had two Discoverys and the 4.0 is a torqey little motor, parts would be available everywhere since there are so many crashed out Discos...
    '77 Caribbean
    Jul 2010
    Quote Originally Posted by alkyexpress View Post
    Thanks!
    Quote Originally Posted by Storz View Post
    Hey, that's not a bad idea at all! I am leaning a bit more towards the 215 though, as it has a history in marine applications, and holds a bit of nostalgia. I would, eventually, use a 4.0 crank and Buick 300 heads to make my own 265, though
    Jul 2010
    Nobody else?
    Ran a turbo 215 in an early pad bottom Beismeyer jet. Ran great but before EFI was available so it was a Hiborn setup. Hard to start and wouldn't idle at certain times of the day. WOT it was fast. Around 80mph. 22 lbs of boost with a single V trim T-4. Used Isky tapered valve springs and a Crower cam. I still have Nicson log style exhaust manifolds. These engine were used on early Berkley pumps that had a plate with an oval nozzle that slid left to right to steer and down below the boat for reverse.
    That will be a great engine. Let me know if you want the logs. I'll scan some pictures and post when I get time.
    Here are some pictures. 16' ~400 lb hull with an A/B cut impeller.
ID:	80769   Click image for larger version.
ID:	80770   Click image for larger version.
