Camshaft for Wet Headers?
Results 1 to 6 of 6
    Senior Member Notalent's Avatar
    Dallas/HB/LBC
    Default Camshaft for Wet Headers?
    Whats the largest size cam duration wise you can run in a wet header system? 236 @ 50 ishh...?
    "Pain is a figment of your Imagination"
    In my 565 I'm running 262/268 @ .050, with a 110 LSA, installed at 109 ICL with no problems, but I do have the spring in the " T " valve shimmed so it blocks water flow to the pipes till 1800 rpm. No flow at idle and the flow stops at 1800 when returning to idle.
    Last edited by Bubbletop409; 07-16-2010 at 09:01 PM. Reason: additional information added
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    I run over 300 duration with 110 lobe centers.
    Quote Originally Posted by Notalent View Post
    Through transom or over ?
    With through transom the engine water gets dumped into the collector so the hose doesn't get burned up.
    My 565" 278-284 @ .050 ( 112 lobe sep) has enough reversion that it pulls water back to the last 2 cylinders on each side while running on the trailer. In the water it idles at 900 rpm with a lope and 1,100 smooth.
    S CP
    Dallas/HB/LBC
    Its a buddys boat out here. 18ft jet with a Berkley 12JE pump...A impellar. Exhaust is a 2 1/4 Thru transom header (Rewarder Racing Headers).
    Engine:
    Ford 460 9.7:1 compression
    Edelbrock #60679Heads 75cc/292cc 2.19/1.76 vavles
    A cam with a 240'ish @ .050 on a 112* lobe ctr will not be the same as a cam with a 240'ish @ .050 on a 108* lobe sep.
    S CP
