Would you run this filter?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 43
    Default Would you run this filter?
    Now that we are all confused on which oil to run....
    what filters are best??
    #55
    hass convinced us to start runnin the kn and im pretty happy with em, no signs of collasp on the last 2 i've cut open.
    Wix Racing Filters and nothing else.
    Kent, WA
    Why not a System 1 ????????
    The Right Coast/SE-PA
    Talking
    Fock, I just blew soda onto my keyboard...
    Mohave Valley/Quartzsite
    I switched to K & N also. After winning a few races they sent me 400+ bucks of filters back when they had a contengency program.. When I'm out I'll probably still run them.. Sure like the 1" nut!!!!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    K&N, then Wix Racing, Napa Racing(GOLD), Mobil 1, Moroso Racing, Amsoil. Just about everything else is junk.
    Senior Member sleekvino's Avatar
    Quote Originally Posted by jbird View Post
    PORNO RACING INC WHERE ITS "HARD" TO WIN
    Fram of course, the racers choice
    Jomar ?
    Lots of good products out there: The Micron rating is interesting ?
    The difference between a 30 micron System-1 screen a 20 Micron Moroso and even a 10 micron K&N is pretty damn small.
    So long as the 10 micron K&N doesn't by-pass and can filter that small that's great. After looking at this subject for the past year. I'm thinking two K&N's, Jomars or Moroso's. Still up in the air. The K&N's are available pretty at two locations around here.
    http://jomarperformance.com/wordpress/?page_id=2
    My bearings had some trash go through them, but it was more than likely from crap in the system. I don't recall them looking that bad before, they typically look pretty good from the System-1 screen ( 30 micron)
    S CP
    The main thing about the Jomar is, if you run a Ford/MoPar typr filter, they don't have a bypass. Most remote filter setups use the Ford filter also. So if you use a Ford filter and don't want a bypass, this is the only filter I know of.
    Somewhere between Paso & L.A.
    what's wrong with a Baldwin B253 Racing filter?
    Kent, WA
    Again ?
    Jomar ?
    S CP
    I got rid of my bypass on my chevy and went to the 2 quart K & N (HP-3002 I believe) which doesn't have an internal bypass.. Unfortunately when I went to a dry sump system I couldn't run the 2 quart K & N anymore and gave them to my oldman.. I'm assuming they make one for a FORD also.. Just a thought..
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
