Blower motor timming
Results 1 to 14 of 24
    Senior Member blurred vision's Avatar
    Apr 2009
    Default Blower motor timming
    BLOWER MOTOR TIMMING, I have a 871 0n a 454,,,, MSD dist locked out at 28 degrees.....can i run more......Thanks,,,,also i run an intercooler
    Chico, Ca
    Quote Originally Posted by blurred vision View Post
    boost, static compression, and fuel????
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    I believe the best way to time your engine is to look at the spark plug. It is easiest to read with a new plug. You want the strap of the plug to loose it coating or color in the middle of the bend.
    Apr 2009
    the motor is 8.5 to 1 compression.....9 pounds of boost.....91 octane....
    spokane, WA
    What pistons? Cermaic Coated? What ignition controller? What spark plug and gap? What do you do with the boat? What rpm? What temp is the engine?
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    Apr 2009
    Forged non ceramic,,,,MSD 6AL MSD dist locked at 28 degrees,,Blower plugs heat range i dont know ....gapped at about .26....Top RPM around 5800..
    engine temp around 120 degrees....Intercooler.... use the boat going up river passing a few peeps...long runs averge about 5000 RPM,,,not wide open.....
    okie, lake Texoma
    If your on pump gas then thats about it, you might get a degree or so out of it but you better watch the plugs because it will start to show signs of detonation if much above were your at. Better off to keep it on the safe side just incase you get a tank of fuel thats not as good as usual.
    H8-2-W8
    [email protected] first pass
    i'm back!! 1QuickCP's Avatar
    Montana
    Ya pump gas is horrible and gettin worse. The motor will be happy at 32 or so if you have decent fuel. Id chuck some race gas in there set it at 32 and see how it runs, then you can decide if better fuel is worth it or not.
    and not one person asked about head material. NAH the ain't big thing
    MD
    not trying to hijack tread
    Im doing my first blower motor. looking for safe timming as well
    468 bbc 8 1/2 to 1 ????? maybe a little less
    flat top with 1 valve relief .020 in hole
    .041 head gasket MLS
    119 cc chambers
    iron merlin 320 (grumpy)
    671 w/ 2 750 holleys ( i think no #)
    35 top
    34 bottom
    super chiller
    cam solid roller (rest unknown)
    92/93 oct.
    NGK # 8 plugs
    Boost ?????? Im thinking 2/3
    Bassett OT w/ water inj.
    im thinking 30/32
    119 cc chambers
    35 top
    34 bottom
    super chiller
    92/93 oct.
    NGK # 8 plugs
    im thinking 30/32
    You'll be fine at 32. There is not much to be gained after 32. i have messed with the timing on blower deals with different boosts and different fuel oct. And never found much in the timing after 32. Raise the boost, and/or the compression and now you need better fuel, but timing still seems to be the same. If the compression low enough, and the heads are alumn., rather than add timing, you'll find more by adding boost. You would have to spend alot of time in a unbossted condition to justifiy adding timing. And then you may need to add a MSD BTM to take timing out when it goes to boost. IMO
    MD
    cool thanks
    Apr 2009
    Thanks guys....Heads are aluminum.......bumped the timming to 32....didnt help alot maybe 400 more rpm...ran a little rough at idle,,,,hard to put in gear....back to a safe 28.....
    Denton, TX
    Default timing
    Thats one thing that worries me is timing. I am at 34. Seems to be a little higher than most.
    SBC, 177SC, 7.1 comp, Iron heads, solid cam, Forged bottom, Running 100LL, only running 4 lbs of boost. EGT reads 750-780C at WOT. I am currently running #7 plugs but am going to switch to a #8 or 9. The timing just seems a little high compared to the rest of the blown deals.
