msd 6+ box tach and rev limiter questions
Results 1 to 14 of 17
    Apr 2010
    Default msd 6+ box tach and rev limiter questions
    I'm wondering what adapter i need to hook my tach up to this #6 msd box, and what my options are for a rev limiter since my ignition box is without an internal rev limiter. I am running the full msd distributor, coil, and ignition box on my 383 Chevy.
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by jeffz0rz View Post
    To hook your tach up, run the green tach wire to the little male spade connector on the side of the box. For a rev limiter, sell your box and get a 6AL.
    Apr 2010
    Are the small plug in rpm modules any good? I saw a few differentsets on msd's website.
    Apr 2010
    I have a single white wire comming out of a plug on the side, is that my tach wire?
    Long Beach
    You've got the Digital 6 Plus box right? The rev limiter chips work fine.
    Go on the MSD site for wiring instructions.
    Apr 2010
    im running the 6m-2 box. i believe i have an extra plug coming out of the box. ill have to dig around for the papers on it to see what that plug is for. are those rpm modules limiters for the box or are they something else ?
    Long Beach
    go to the MSD website and you can pull up your wiring diagram.
    you will have:
    a purple and green that both go to the distributor.
    a white that is only used if you have points
    An orange and black that go to the coil
    a big red and big black that go to the battery....even though MSD says not to...put a fuse on the big red wire.
    A little red that goes to the key
    then there is a little spade terminal in the side of the box...your tach wire plugs in here.
    If you have an "L" box, you will have 2 little round holes that accept the rev limiter chip. I'm not familiar with the marine boxes so aside from being a 6A painted blue and full of epoxy, I'm not sure if there are any other differences.
    Apr 2010
    awesome, ill check it out tomorrow in the day light. thanks for the info.
    The MSD 6M-2 does not have a built in rev limiter. It requires a 8768 soft touch limiter. It is the only limiter that works with the 6M-2. The 6ML-2 has a built in limiter.
    http://www.summitracing.com/parts/MSD-8768/
    Senior Member TurboNova's Avatar
    Dec 2009
    Lake Havasu City AZ
    On the 6m the grey wire is the tach wire.
    Apr 2010
    Hooked up the grey wire to my tach, but it cant be accurate. It's reading way too high I think. What is a moderately low idle rpm for a sbc? I think right now its pretty low. But the tach is telling me its at 1200.
    Apr 2010
    Anybody have this issue with a tach?
    Nov 2008
    Orangevale CA
    does your tach have a switch for 4 or 6 or 8 cyclinders ? ........E
    Apr 2010
    No switch. It's a fariah marine tach. Nothing special, but it matches all my other gauges. I'm going to have to swap it out arent i...
