Oiling Question HELP
Results 1 to 11 of 11
    Senior Member Cobra 02's Avatar
    Montclair
    Default Oiling Question HELP
    Oiling Question Posting for a friend.
    Fresh motor has oil pressure at the gauge 40 psi when cranking the motor over, but no oil is getting up into the heads, what could be the problem.
    Gen VI 454 AFR 305's
    cfm
    cfm is offline
    Problem could be that no one spun (primed) the oil pump for a while before he received the motor. Get a oil pump primer w/collar and spin it with a drill until the oil comes out of the pushrods/rocker arms. Could take a while. If it never happens doing this then a plug could have been left out of the block.
    The Right Coast/SE-PA
    X2
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    What block is it, what year, what diameter cam shaft, what heads and what size (diameter) lifters?
    Montclair
    What plug ?...The plug or what ever its call undernieth the oilfilter adapter is left out, would that do it..
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    What engine are we talking about here or did I miss something?
    '57 J2 Olds....
    Just guessing....
    Quote Originally Posted by Cobra 02 View Post
    If your friend's block is a Gen 6 block,, like yours, NOT using the remote cooler lines from the block, then it's good to remove the pressure bypass that is in the block directly above the threaded oil filter adapter, since it diverts the flow to the passage in the block rather than allowing oil from the filter to return directly to the block.
    There are different types of oil priming tools, if it's a plain one with nothing to simulate the distributor being in place, then it won't prime the top end, so it may take several moments of the engine running to bring oil to the top end.
    Even if all the plugs are in, and you use the right priming tool, it is still possible to not get oil to the top if your lifters are edge orfice type. You can spin it for days and never see a drop in the heads.
    Rural Missouri
    Noticed that you edited your original post to include: "Gen VI 454 AFR 305's".
    Given that, that answers most of my questions except lifter manufacturer, type & lifter bore size.
    Does any oil show at 8 & 6, or no oil at all?
    If no oil shows anywhere and your friend used Fel-Pro head gaskets ..... that may be a significant contributor as Fel-Pro's do not align with AFR 305's and could be blocking oil flow.
    Another thing to consider is that your dealing with GM's 'Priority Oiling System' that definately does not work with very tight/small lifter wall to lifter bore clearances.
    [QUOTE=1/4 Miler;1174688]
    Quote Originally Posted by 1/4 Miler View Post
    Can you please explain how a head gasket keeps oil from going to the head of a BBC?
    Only if the lifter is an edge orfice lifter. Has very little effect on hyd and and standard solids with the oil hole in the band area.
