Selecting intake
Results 1 to 1 of 1
Selecting intake
    Member SCREAM'N MAD's Avatar
    Jul 2010
    WI.
    Default Selecting intake
    What carb/ intake set up is good for this motor?
    I am looking for some good torque/power.
    with this motor?
    Berkeley Jet drive 12jb-a
    no dirverter, was my next purchase if i keep it
    motor consists of: 460/450+hp
    king bearings
    hastings wrist pins
    hastings hydraulic lifters
    hastings piston rings
    silvolite pistons with .072 dish
    melling oil pump
    melling timing chain set
    lunati cam
    CAMSHAFT SPECIFICATIONS:
    Ford 429-460 c.i.
    APPLICATION CAMSHAFTS
    VALVE SETTING
    RPM
    OPERATING
    RANGE
    CAMSHAFT PART NUMBER
    CAM GRIND NUMBER
    DURATION
    VALVE LIFT @ 1.73:1
    LOBE SEP. ANGLE
    ADV.
    @ .050”
    IN. EX. IN. EX. IN. EX. IN. EX.
    HYDRAULIC FLAT TAPPET: Rough idle. needs headers and 3.55-3.90 gear with 2000+ stall converter.
    Hyd
    Hyd
    1500-5500
    11602
    NA
    272
    280
    224
    234
    .543
    .569
    112/107°
    holley 650cfm double pumper carb
    edelbrock air cleaner
    mr gasket chrome high volume fuel pump
    edelbrock performer rpm intake
    stock heads with new valve stem seals
    glenwood water injected through transom exhaust
    mallory unilite distributor
    accel super coil
    accel 8.5mm wires
    new timing chain cover
    nicson water pump cover
    prestolite marine alternator
    guardian and nicson engine mounts
