best carb for PFM twin turbo 460 ford??
Results 1 to 5 of 5
    Senior Member mercdrag 2.5's Avatar
    lansing
    Default best carb for PFM twin turbo 460 ford??
    rite now all it has is a 750 vac carb. is a 850 DP big enuff or should I look for a 1150 holley?? thanks
    2008, 2012, 2013 and 2015 world series of ice drags champion prostock 800!!
    http://www.youtube.com/watch?v=MMfL6HI_o_8
    okie, lake Texoma
    Quote Originally Posted by mercdrag 2.5 View Post
    my setup had a boost referenced 1050 dom. worked great, the whole setup is forsale in the spam section.
    H8-2-W8
    [email protected] first pass
    Douglas, MA
    I have a milled out 850 boost referenced on my draw through system that works very well. Which size turbos do you have?
    I did notice you are running a pcv valve...how is that working out for you?
    lansing
    thanks looks like ether carb may work well on his settup......
    ....so far we have had no troubles with the boat but have only put 20 gallons of gas or so.....only seeing low 70's on the GPS but dont think the carb is the greatest!! not sure the size of the turbos, they are rayjays and show 7-10 lbs of boost @ 5300 rpm's.
    MI
    Put that thing on E85. Nice boat BTW
