Aluminum heads
Results 1 to 14 of 32
Aluminum heads
    Custom User Title
    Lago Vista, TX
    Default Aluminum heads
    I think I already know the answer but due to my engine budget constraints have to ask anyway....
    Has anyone ever heard of Terry Walters Precision Engines???
    http://www.waltersengines.com/
    Has BBC aluminum heads for $1495... Are they just more Chinese junk?
    http://www.twperformanceparts.com/product/TW1203BBC
    Flow Numbers
    Intake________Exhaust
    .100_74.3____.100_62
    .200_66.11___. 200_118
    .300_245.36__. 300_160
    .400_308.05__. 400_195
    .500_339.84__. 500_229
    .600_360.43__ .600_248
    .700_374.31__. 700_265
    I would be very VERY sceptical. Flow numbers aren't very good for a 320cc port. Sure as heck isn't made in the US for that price. I would call them and ask as many questions as you can.
    i'm back!! 1QuickCP's Avatar
    Montana
    ummm...shipping weight 65 lbs? quanity 1 price 1495.00 im thinkin EACH
    if its for the pair ?
    u buy,this head good,it clean,flowy flowy 1400 us dollar..it have happy ending 4 sure !
    Same ole POS as the Pro Comp. Same head, same country of origin, the same dickhead marketer. He just wholesales them out to too many ventors to even keep up with.
    These guys are no better. Want to market a rod or crank under your name, these are the guys to talk to. We got your cranks, your rods, your rockers, dampers, and now 351 W Ford blocks. We can set you right up. Alas, you are able to built a 351 W without using a sigle USA built part.
    http://www.rpmjointventure.com/F/21/default.asp
    Custom User Title
    Lago Vista, TX
    I sent an email asking if that price was for each or a pair.....
    Here's his reply..
    Hello Boat Man,
    They are for a pair. We are now offering a fully CNC version for $1950.00 a pair .Thank You Terry
    I guess if I want to waste some money on shipping I could order a set and have them delivered to Jim Valeco and see what he thinks..
    Doug
    .......wonder if it's a Chinese CNC machine....
    Better idea! Send me the money instead, I will tell you what I think of them.
    Same head:
    http://cgi.ebay.com/ebaymotors/Strik...item563e433dbd
    Same head:
    http://cgi.ebay.com/ebaymotors/BIG-B...item51941b3fb3
    Same head:
    http://cgi.ebay.com/ebaymotors/BBC-C...item5885d7c24e
    Same head:
    http://cgi.ebay.com/ebaymotors/BBC-C...item3cad97440c
    I could keep going. But you get the idea. All the same head, from the same supplier. There are probably another 6-8 guys selling on E-bay alone. Boggles the mind about how many sets of these are being moved.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    Ive been looking at the Doug Herbert bbc alum heads, are these any good?
    Chevy BB Heads 320cc
    320cc intake runner
    115cc combustion chamber
    Hydraulic roller camshaft
    1.520 Dual spring .675 max lift
    2.250 stainless intake valves
    1.880 stainless exhaust valves
    ARP 7/16 rocker studs
    Comp Cams 3/8 guide plates
    Comp Cams 10 degree Super locks
    Herbert performance valve springs
    Herbert Chrome Moly 10 degree locks
    Move your mouse over image or click to enlarge
    $1,199.99
    320cc intake runner
    Add to Cart:
    • Model: DHPHEADS-HR
    • Manufactured by: Doug Herbert Performance Parts
    Quote Originally Posted by Mash on It View Post
    320cc intake runner
    $1,199.99
    320cc intake runner
    Add to Cart:
    That's not a pitcure of a BB head, FWIW...and I can just about guarantee Herbert doesn't "manufacture" those.
    I've seen HERBERTS HEAD. SAME HEAD!
    The head in the pic is a ProCrap vortec.
    Willow Beach & BHC
    for a mild build would the herberts be better than 781's? the shot ones i have need $800-1000 worth of work (large valves, springs, guide plates, etc,etc)
    1200+/- And losing weight?
    It seems as the magic thing with this frick'n POS heads is that they are made of the wonder metal of wonder metals......aluminum. How grand! I would rather buy a set of cast iron Darts or Merlins, or RHS than run a free set of these POS heads. But if you are hell bent to have racey look of aluminum then by all means buy them. It makes no difference whether you get them from doug Herbert, or E-bay, or straight from ProCom Electronincs, they are all the same frick'n POS head. Just remember, the job you cost by buying those heads, may be your own. (or at least hopefully)
    Somewhere between Paso & L.A.
    Talking
    FRIENDS DON'T LET FRIENDS BUY PROCRAP!
    (just call steel about a set of Canfields he's got)
    Menifee
    Stay away from Pro Comps and their copies!!!
    My son has a set on his true flat Hondo. It's a pump gas 427 with a small baby flat tappet RV cam and a tunnel ram with a couple 650s. It only runs 90 mph. Thinkin it should run atleast 100. We are sure the Heads are slowing it down a ton so we are going to run a set of 049s and pick up a shit load of power.
    Keith...
    Jun 2011
    Default Fwiw
    Catching this thread, even though it's a bit older there's a few things to be addressed.
    1) Terry Walters has been in business for 30 years (Check out his website under walterengines in google).
    2) Where we can agree that there have been several problems with Pro Comp parts, if you do your research (again) on the actual ProComp Castings as of late they've improved from where they've been
    3) The difference between these heads, and the ones you but from EBay should be apparent if you look at the specs of the head itself. Notice how the chamber size is 119, not 115, and the flow numbers are different from what ProComp advertises. I actually talked to Terry Walters personally, and after a bit of conversation about an intake, this subject came up. What he's doing is buying the ProComp castings for cheap, and fully re-machining them in his facility. Then, from the exact cam you give him (not just Mech. FT, Hyd. Roller ect), he's using Manley/Comp Cam parts to put your valve train together, and setting spring height for you, based on your exact specs. He'll tell you himself that buying a assembled set of heads from ProComp is a bad idea, because they're filled with a bunch of junk parts, and have obvious alignment issues.
    Personally, I think you're caught between the dilemma of "Foreign Junk", vs a known professional engine builder. Where I probably wouldn't run this in a straight strip engine; a budget street, or street/strip engine wouldn't sound like a bad idea, and according to the flow numbers would work well for a 454-427.
    I don't personally know Terry, or have a set of these heads. But for the work that looks like he puts into them (and posting what seems like legitimate flow numbers that match very close to patriot heads), I'd second guess myself to bash this guy with the rest of ProComp retailers.
    If you have questions, do what I did and actually pick up the phone. Don't expect an old man to enjoy writing e-mails!
