overdrive or undrive
Results 1 to 7 of 7
    Emmett, Idaho
    Default overdrive or undrive
    550 cid bbc 8.5:1, dart 320s that flow 400in/ 300ext cfm (ported), isky rr-730-b (730/727 lft, 282/288, 110 lc, 112 ls), and 8-71 w/2 1150 dom.
    my question is where should i start with pullies? the pullies i have are a 43 and a 45 8mm. looking to get about 6-8 psi boost. this is a pump gas motor.
    thank you for any info
    trevor
    Nov 2008
    Orangevale CA
    trevor
    try the 43 on the bottom , that is 5% under, If you want more power then put the 45 on bottom and 43 on top 1.05% overdrive, ..........E
    Close to the water...
    Quote Originally Posted by alkyexpress View Post
    Simple if you lose switch pulley position. Fixed It for ya Good luck Trev, hopefully there will be a E-85 station in the future close by.
    With the 43 upper and the 45 lower your looking at close to 8lbs, with the reverse your looking at about 6lbs. Its a good selection of pulleys for a start because it puts you close to where you want to be, with out being a huge difference when switched.
    Ps. That is a nice combo you have there. Ask me how I know Of course it is even better with a bit more compression and race gas! I think your cam may be a little long for your boost level, but it just makes your deal a little safer from detonation. The 730A may have been a better choice. I have found that cam works a little better 4* advanced.
    Emmett, Idaho
    thanks gn . no worries on the compresdsion the motor is actuly 9.5:1 but i added a .075 thick head gasket to get some copression out of it. so if this is not what ium looking for ive got a .040 gasket and a bird catcher on the shelf ready for alky.
    Nov 2008
    Orangevale CA
    THANKS FOR THE HELP STEVE ; , lol
    [QUOTE=gn7;1177882]With the 43 upper and the 45 lower your looking at close to 8lbs, with the reverse your looking at about 6lbs. Its a good selection of pulleys for a start because it puts you close to where you want to be, with out being a huge difference when switched.
    THANKS GN-7 , this is what I was trying to say,
    [QUOTE=Reservior Dog ) so if this is not what ium looking for ive got a .040 gasket and a bird catcher on the shelf ready for alky.
    NOW I CAN ACTUALLY HELP YOU HERE !!!!!!!! lol .........E
    Emmett, Idaho
    thanks alky
    steve i hope they get that e-85 here soon. see ya on the water soon
    trevor
