Stroke...stroke
Results 1 to 9 of 9
Stroke...stroke
    Douglas, MA
    Default Stroke...stroke
    I don't know much about stroking an engine...but I was curious what is involved.
    This is just a 468 4 bolt main that I have a set of turbo's on...but if I wanted to stroke it to a 502 or ? Could I? What is involved? Is it worth it?
    Since the engine is pretty fresh I probably won't be doing anything for a bit, but like I said...just curious about the stroke.
    Buy a stroker kit and build a 496.
    Douglas, MA
    like a speedomotive deal?
    Senior Member lbhsbz's Avatar
    Long Beach
    Your stock stroke is 4.00". The next step is 4.25". You'll need new pistons with a different pin height to compensate for the longer stroke. It's also a good idea, but not mandatory, to go to a longer rod...6.385" instead of your stock 6.135" rods to keep the rod angle reasonable.
    So, you'll need:
    4.25" stroke crank
    6.385" rods
    pistons
    Oh, and speedomotive sucks. I would shop elsewhere.
    Peoria, AZ
    The one other detail is that you might have to do a little bit of block clearancing to make sure that you have plenty of pan rail and cylinder clearance. On the last three I built I had to clearance the pan rails and part of the bottom of the cylinder walls. Here is a picture of one of the blocks I did a few years ago. I needed to clearance the bottom of the cylinder walls and only a touch of one of the pan rails. (I did not want to post the picture as it is really big)
    http://i278.photobucket.com/albums/k...d/IMG_0938.jpg
    Paul
    Douglas, MA
    So, you'll need:
    4.25" stroke crank
    6.385" rods
    pistons
    What is kind of the 'maximum' stroke (cubes) on a regular block these days? I remember my uncle did a 502 some time back...what a freakin' torque monster that thing was (especially after he Turbo charged it )
    Again, probably not something I am doing any time soon, but just curious so I can get my mind working
    Speedo sucks...gotcha.
    I think flatlander racing was another one I used to see. Some one from the board said they had a pretty reasonably priced kit too.
    MI
    Don't forget a new internal balance flywheel, balancer, and a stroker oil pan.
    Kingman/Golden Vly, Az
    Quote Originally Posted by sanger rat View Post
    NOT necessary!...my Scat crank uses the external balancer, flex plate & my Milodon 10qt pan fits just fine ...after all parts are aquired for the build, take everything & get it balanced!
    FastRat
    Your uncle didn't build a "stroker" 502. It was either a 502 to start with, which is a just larger bore 454, but requires a different block than a 454. Or, his stroker was really a 505. Which is a 454 bored .100 over and a 4.25 stroker crank.
