jetting help please
Results 1 to 2 of 2
jetting help please
    Senior Member californiadreamin's Avatar
    Feb 2010
    Temecula CA
    Default jetting help please
    heres the motor:
    455 Olds .030 over
    80cc factory iron heads
    9.8:1 comp
    12* initial and 30* total timing
    284 int 288 exh duration .560 lift solid roller
    heres the carb:
    holley 3310-1 780 cfm vacuum secondary
    83s in primary and 84s in secondary
    running pump gas and i have no coloring on the plugs. it a fresh motor with hyperutectics im very leary about running this thing dont want to melt these pistons down. any thoughts?
    Learned some hard lessons with Hypers (not sure which you have) nearly 10 to 1 you'll probably be OK with 91 you could actualy get away with 34* Tom
