Backfire at idle
Results 1 to 14 of 16
Backfire at idle
    The Great Humongous P-Money's Avatar
    South Central WI
    Question Backfire at idle
    I keep getting a sporadic backfire out the exhaust at idle. Let it run on the trailer for 20 minutes yesterday and after it started to warm it the popping began. Gas is good, distributor cap is new. Starts right up, idles smooth, just has this goofy backfire out both headers. Not continuous, seems to come and go. Plugs look good.
    468, 660s, 990s, msd pro billet distributor, crane hi-6, bg280, bassetts...
    Any thoughts where I should be looking?
    Close to the water...
    Just a wild hair guess but I had friends twin engine boat backfire at times on one engine and quit at other times when warm, I found a ignition switch getting hot. put a new switch in no more problems
    Lake Havasu az.
    Missfire...or full blown backfire? Might try slidding the spark plug boots off the plugs with a grounded or insulated screwdriver....just far enough so the spark has to jump inside the boot...it will get you one of 4 things.
    If the miss fire stops, and the motor runs better it's probably a spark plug problem
    If it runs worse and the misfire stops it probably a wire.
    If it misfires the same and runs worse, it isn't that cylinder.
    And if ya get knocked on your ass ya probably don't know what a grounded or insulated screwdriver is
    Sheriff Joe Arpaio
    spokane, WA
    Headers? Wht do the exhaust gaskets look like?
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Quote Originally Posted by TwinTurbo540 View Post
    X2, i had a issue that chased down for days where it would back fire when i gave the throttle a slit blip on the trailer. Turned out it was my exhaust gaskets leaking. From what i was told you end up letting fresh cool air get sucked back into the motor and it causes a lean backfire.
    SoCal
    Check your Crane ignition box. Ive ran a into similar problem with them before.
    spokane, WA
    Yup, seen it more than once!! Sometimes it just something simple that gets over looked..
    Travis
    9[email protected]
    Ohio
    I had a Crane box go bad but it had a miss from 3000 rpm and up.
    Tim
    Frst Round Runnerup Hondog's Avatar
    Turlock, CA
    Travis
    X3.
    Gone
    Sparks, Nevada
    Pull the valve covers and check things....just because.
    Orlando.FL
    X 2
    Southwest corner AR
    Flat tappet cam or roller?
    WT
    WFL Crew!!!
    The Right Coast/SE-PA
    I know where you're going with this...been there, done that > and it sucks
    Sep 2008
    Yuma, Az
    x2
    boatless....
