car vs marine battery
Results 1 to 6 of 6
    Mar 2010
    Default car vs marine battery
    Hello everyone, I was wondering what does everyone run and what's been your experiences with car batteries vs. marine batteries? Any recommendations on any particular brands or types? Thanks in advance for any insights.
    Lost Wages, NV
    Depends on your use...
    In my boats, I always go with the marine version - the main difference is that the marine version of posts on top vs side bolts. I run Optima batteries...good warranty and decent price.
    Optima makes a deep cycle, lower CCA battery and a "starting", higher CCA battery. For my engine batteries, I run the 1000CCA starting battery. For the stereo, I use the 805CCA deep cycle battery. While the starting battery is higher amps, its rated lower in Ah (amp hour). The deep cycle is lower cranking amps, but higher Ah rating. This means it will run longer, but at lower outputs.
    Keith-
    Senior Member lbhsbz's Avatar
    Long Beach
    Marine means a sticker and a bigger price tag, and usually a shorter warranty. I like the cheapest lead acid battery I can get my hands on.
    How do you make it last? Use it. When things sit...they rot, including batteries....use the battery...any battery, and it will last a long time.
    Break Out Another Thousnd Sanitariumflat's Avatar
    X2. And keep a Battery Tender or other battery maintainer on it. (not a trickle charger). I've had real good luck with the red optimas.
    Smash
    RIP Jeffrey Lee Aschwanden. Godspeed bro.
    Thank You for all the help Mr. Bandit !!!
    Quote Originally Posted by nelson#109 View Post
    id rather work with an ass hole that knows his shit, than a nice idiot.
    cfm
    cfm is offline
    Interstate Marine is pretty good. They also just changed their warranty from 1yr to 2 yrs. Price went down a tad also.
    I stock them so pretty easy for me to get one when needed.
    Mar 2010
    thanks everbody for the input, I picked up a Deka 800cca marine starting battery for $90 out the door. With a 1yr replacement and 48mo pro. warrenty.
