Mechanical Fuel Injection - Flowing
Results 1 to 10 of 10
    Kent, WA
    Default Mechanical Fuel Injection - Flowing
    Is there a way to add an attachment that is an Excel spread sheet ?
    Last edited by wizbang; 08-09-2010 at 08:20 PM. Reason: Want to load an info sheet on a thread ?
    Lost Wages, NV
    Probably easier to shoot a screen capture and upload a picture of it than the actual spreadsheet.
    Keith-
    Kent, WA
    Ok, I'll try this ?
    Do any of you think about what pills and nozzles really flow when they are NOT flowed and you use them without having them flowed ?
    We have a flow bench at the fuel car shop. We flow all the nozzles and pills for the car. I am lucky enough to be able to use the bench for the boat stuff also.
    Have you ever changed a nozzle or pill and scratched your head when it made a opposite change ?
    There is the Kinsler "set" I have and also a Waterman set.
    The left column is the number that Kinsler has in the pill.
    "Num" is the number showing as flowed or flowed forwards.
    "No Number" is the backwards flow.
    We use the drop in style pills, that way we get two different sizes from each pill.
    Also, I flowed some more nozzles. These are Enderle screw in nozzles.
    I am not pointing fingers at the manufacture or at anybody, I just wanted to share the flow bench info !
    Kent, WA
    Ok, that didn't work so good, can somebody please fix the pics ?????
    I sure hope your better at tuning that boat than your are at posting spread sheets Are you the same guy they let select the valve springs?
    Lost Wages, NV
    Way too small...your screen resolution must be WAY up. Try clicking VIEW and ZOOM in on that part of the screen, then do the screen capture.
    Kent, WA
    [QUOTE=gn7;1186811]I sure hope your better at tuning that boat than your are at posting spread sheets Are you the same guy they let select the valve springs?
    I'm just WAY too cheap to buy new ones
    Kent, WA
    Quote Originally Posted by STV_Keith View Post
    Send me a pm with your email address, I'll send the sheets to you ?
    Would that help ?
    Back into Boats Beal Motorsports's Avatar
    Dec 2009
    Kansas City
    We try to buy flowed nozzles/pills from Enderle. But we don't use drop in pills, we use a K style valve and thread it into the body. It seems different benches show different numbers. We're fine as long as we stick to one source.
    Kent, WA
    Quote Originally Posted by Beal Motorsports View Post
    I have tested our bench against Davenports flowed stuff. I use Sean's program to tune also.
    We just flowed a K valve and now are making some software to allow us to simulate the total throttle range.
    The guy that made us the software and the flow bench also flows his Holley jets,,, funny how they are so "screwed up " too
    I can't figure out how to get the sheet data on here, if somebody wanted to see them and how they compare just for info, I can email them !
