How to determine octane requirement?
Results 1 to 13 of 13
    Massachusetts
    Default How to determine octane requirement?
    I was told to run 93 octane in my SBC Vortec 5.7. It has about 32 degrees of total timing, stock heads and pistons. Premium costs $0.20 more per gallon. Can running premium when not needed lead to carbon fouling from the slower burn? Short of using a ping sensor / warning system, how can you determine the octane an engine needs?
    Real Boats Don't Have Propellers!
    -- Rivernut
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by Rivernut View Post
    What's the compression ratio of your stock motor? If it's less than 9.5:1...I wouldn't waste my money on the race gas...I'd use '87. If you want...I've got a knock sensor setup you can borrow/buy to see what it's doing....has a little light bar that tells you when it's about ready to explode. I know it works....cuz it told me right before I .... nevermind. You might be able to use it though. send me a PM.
    Massachusetts
    9.4:1 stock pistons and heads.
    -- Rivernut
    Aug 2009
    O.C. & Lost Lake
    If you can't afford that extra 20 cents, you can't afford a boat.
    cfm
    cfm is offline
    Stock GM Marine Vortec will run fine on 87. GM also states this. I prefer to be on the safe side of things and would run 89 if you can, especially if you tune things more to the edge like most of us Hotrodders do to get 'a little more' out of things.
    Quote Originally Posted by GM Marine Website's Literature in .pdf
    Specifications
    2011
    © 2010 General Motors
    www.gmpowertrain.com
    GM Powertrain
    747.0
    (29.42)
    559.0
    (22.01)
    217.0
    (8.54)
    510.0
    (20.08)
    255.0
    (10.04)
    Type: 5.7L V-8 (Gen 1e Small Block)
    Displacement: 350 cid (5736 cc)
    Engine Orientation: Longitudinal
    Compression Ratio: 9.4:1
    Valve Configuration: Overhead Valves
    (2 valves per cylinder)
    Assembly Site: Toluca, Mexico
    Valve Lifters: Hydraulic Roller
    Firing Order: 1-8-4-3-6-5-7-2
    Bore x Stroke: 101.60 x 88.39 mm
    Bore Center: 111.76 mm
    Bore Area: 648.59 cm²
    Fuel System: N/A or Port Fuel Injection with
    electronic throttle body unit
    Fuel Type: Regular Unleaded
    Massachusetts
    Lost Lake is a Whie Trash settlement.
    -- Rivernut
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    what?
    what?
    I gather he is refering to a different Lost Lake, in a different state. Based on his avatar. Then again, I am clueless to what Whie even means
    Cole SS cole ss's Avatar
    Rochester, wa.
    What octane gas should I use on my stock compression 1990 454 and why? Does it help to use high octane on a low compreesion motor? Thanks
    Long Beach
    Quote Originally Posted by cole ss View Post
    the cheapest gas you can find. Octane = knock resistance. low compression engines don't need the knock resistance of 87 octane, let alone 91 octane
    No...it will only make it faster since your wallet is lighter and you're carrying less weight.
    Run the 92. I have done what I think is pretty intensive tests on the vortec headed 350. However, these tests have only been done with a carb.
    Massachusetts
    Burnt Sticks lists Lost Lake with his idiotic comment. Lost Lake here is carnie-ville. Back to octane discussion- do knock sensors work to help dial in timing, jetting and octane? Do they pick up false sounds of impellers or aluminum hulls banging around in chop? And again- does running a higher than needed octane cause carbon build-up from incomplete combustion?
    -- Rivernut
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    B. Lost Lake here is carnie-ville.
    Never been there, but that is funny.
