Lifters
Results 1 to 14 of 16
Lifters
    Senior Member Hallett's Avatar
    Lakehavasu az
    Default Lifters
    Has anyone used these lifters yet .
    http://www.iskycams.com/BearingFlyer.pdf
    Thanks Bob.
    Newton Ks.
    Sounds pretty nifty. I'd consider giving them a spin if I was in the market. Just a babbit bearing really, oil fed from the lifter gallery.
    H.L. Mencken
    Senior Member Sanger Greg's Avatar
    SFV LOS ANGELES
    Default isky lifters
    i have used isky roller lifters for years with my blown 598's they had bad bearings in the past, they were the only cause of engine failure that i have had in 7 years. They have changed the bearings since then. I now have the second gen bearings no failures yet. The new ones look good.
    Shell Knob, MO
    Yes, I have them in our purple race boat engine and I have them in my blown gas 588 Chevy in my lake boat. Both sets are new enough that I have no idea of longevity yet. They look like a real good deal. They will definitely take some of the slack out of the valve train. I'm running about 350 lbs of seat pressure and over 950 lbs of open pressure so it should be good test of their durability.
    B1 Racing cs19's Avatar
    A friend built 2 seperate drag racing engines, both had those in them and both failed right away. Isky had a bad batch go out the door and they know about it. Apparently they made it right and replaced everything that got wiped out. There are others out there using them with good results from what I have read on other forums.
    Im running LSM .937 keyways and Im very happy with them so far.
    B1Racing.net
    Shell Knob, MO
    CS19, Were the failures with the Red Zone or the E-Z roll lifters?
    EZROLL
    We are running red zones in another deal thats a .750 lift river boat been good so far. Had em rebuilt after a season just to be safe and will probably continue to do that.
    B1Racing.net
    Shell Knob, MO
    Thanks for the reply. I guess I'm the genie pig here. But I've always had my best luck with Isky valve train parts. I know I'm sure scared of the new ones from China that comp is selling now. I'll let you know if I run into any trouble.
    Senior Member Red Rocket's Avatar
    winchester, ca
    I am running the EZ-ROLL in the motor of my race boat, the first set the bushings went out after just a few runs. Isky took care of everything and the new ones are holding up fine. I'm running about 1050lbs over the nose and just under 400 on the seat. I also have several engines with the red zones both drag race and endurance applications and are really happy with them. I send them in to be rebuilt after two or three seasons depending on useage.
    Shell Knob, MO
    What oil are you using in your engines?
    I usually break in with Kendall GT-1/GMESO, then switch to Mobil one.
    winchester, ca
    In the race engine I'm running the Joe Gibbs XP1. I have not been happy with cam wear in the past so this go around I'm trying this. It is supposed to have a very good additive package that will extend lifter and cam lobe wear. Before I was running Synergyn and was happy with everything but lobe wear. The endurance motors I'm still running the Synergyn and quite happy with it. I have one endurance motor that I'm trying the Brad Penn oil in, interested to see the results have heard good things about the Brad Penn products.
    Senior Member Pattymelt18's Avatar
    If im not mistaken the easy roll standard with all red-zone lifters i thought that was the point of them.
    Canyon Country, CA
    Quote Originally Posted by Pattymelt18 View Post
    i believe the e-z roll is an option on the red zones
    Lakehavasu az
    Yes i think the ez - roll are about 875 a set. the red zone are cheaper. thanks for all the great info .
